Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 03-18-2005, 09:25 PM
yaguilar yaguilar is offline
Talking NEED HELP? & u get $50
My car is leaking antifreeze, I forst thought it was the radiator, so repalced it, plus it was cheap only $180, new with lifetime warranty, I also bought the new radiator hose that goes from the engine to the radiator. The problem was fixed, on monday morning as I am getting ready to get to the car I noticed a puddle of antifreeze, i though it was from the old one , so i went to work and when i got out there was a large puddle, i checked the hood and the antifreeze from the pump was all gone, so i pour more and as im driving to get home,I noticed smoke was coming out so I pull over and i get out "i automatically thought my water pump broke, so i open the hood and no smoke came out!" and i still had antifreeze, so i get back in my car and drive off as im driving i see smoke again , i stop and get out to see that the car was smoking from the passingers side at the BOTTOM!! I got home parked the car and smoke was coming out of the vents,, but I never turned on my heater (plus the car is parked and turned OFF!!) PLEASE, HELP ME TO FIGURE OUT WHAT' S WRONG WITH MY CAR???? I AM WILLING TO PAY $50 THANKS EMIAL@ [email protected] with ur info.
Old 03-19-2005, 12:39 AM
LTZ9C1 LTZ9C1 is offline
Have you checked the heater core hoses for leaks and or the heater core itself for a cracked tubing that protrudes into the engine compartment?
Old 03-19-2005, 07:40 AM
CD Smalley CD Smalley is offline
Re: NEED HELP? & u get $50
Steam out the vents definitely sounds like a heater core like to me too. Depending on the year of your car it could be a very easy fix. If it's a 77-90 the heater core is located under the hood and cam be replaced in about 30 minutes.
CD
1991 W41 #142
1989 Caprice 9C1
1997 C1500
1997 Bonnie SE
1998 Olds 98 LS
Recently updated: http://forums.b-body.org
Old 03-19-2005, 09:20 AM
dramey_2004 dramey_2004 is offline
leak
ya if you have been smelling a real sweet smell or a hasing on the front window this defantly sounds like a heater core problem. This is not a hard fix just a time consuming most likely being inside your dash. keep us posted
Old 03-23-2005, 09:16 PM
evile69 evile69 is offline
If The Windows Instantly Fog When You Turn On The Def. You Mightneed A Heater Core 90 And Back Take Off The Black Plastic
Cover On The Right Side Of Fire Wall Be Carefull May Crack Easy When Removing Look Inside For Coolant At The Bottom If So Replace The Core.
