Go Back   Automotive Forums Car Chat > Honda > Odyssey
Old 03-18-2005, 09:20 PM
njdude njdude is offline
Question Dust/Pollen filter
Where is it??? How do I change it? HELP!!!
Old 03-19-2005, 05:01 PM
lorunner lorunner is offline
Re: Dust/Pollen filter
Behind the glove box. There is two 8mm bolts under the glove box, remove them and remove the box. Once removed along the bottum where the box mounted to you will see a plastic strip the same color as the dash. Behind it is a metal bar. You need to cut the plastic piece off to get to the bolts behind it and to get the bar out. Once the bar is out then remove the acces panel from the evaporater housing and pull out the filter.
Stop asking me about radio codes I cant get them anymore!!!
Old 04-05-2005, 04:26 PM
andrewshih andrewshih is offline
Re: Re: Dust/Pollen filter
Cut the Platic Piece?!?!?!? Is there a way to remove it WITHOUT cutting???
Old 04-06-2005, 03:46 PM
No its part of the dash. The main purpose is to hold the dash together during installation at the factory. The only other way i guess would be to remove the whole dash.
Old 04-10-2005, 04:52 PM
BullShifter's Avatar
That is one stupid design. My fav. part of replacing those cabin filters is cutting that piece out. The only way around it is to remove the whole dash. Cut the piece and be done with it.
I think cabine filters are worthless, humans have survived how long without them?
Old 08-13-2005, 10:24 AM
Tonyb416 Tonyb416 is offline
Ok, I'm a total newbie, I'll admit it. By 'behind the glove box' do you mean to open the glove box and look behind it? Or do you mean, look underneath the glove box? When I look underneath, I see two bolts towards the rear of this black plastic tray/housing unit. Are these the two bolts you mention? The tray/housing unit seems to have a rounded piece towards its front with some sort of plastic clip that snaps down onto it (am I even in the right place?). There are also two more screws that seem to be securing this plastic tray to the dash. The two screws are closer to the front of this tray.
Thanks for clarifying.
Old 08-14-2005, 01:24 AM
Re: Re: Re: Dust/Pollen filter
You need to remove the glove box as stated by lorunner. Look under it for the hinge, cleary visible, at each end are the 2 8mm bolts.
