Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 03-18-2005, 09:13 PM
phonix phonix is offline
interior lamp control module 99 suburban
Can someone tell me where the interior lamp control module is? I searched high and low, could not find anythin similar to what the dealer sold me. I have remote keyless entry and don't think there is such a thing in this truck. My dome light is always on, after hearing clicking , I traced the source to be the remote function activation module. Could this be the problem of dome light always on?
Thanks
Old 03-19-2005, 09:16 PM
Eggert Eggert is offline
Re: interior lamp control module 99 suburban
Hi,
this may not apply to you.
I am not sure if your 99 is the NBS (New Body Style) or OBS (Old Body Style). In my NBS Yukon XL this is governed by the BCM (Body Control Module) located to the right of the steering wheel behind the lower steering wheel cover. It has 3 large connectors arranged horizontally.
I doubt that you bought a BCM, it is not cheap and you have to reprogram it.
Just in case, here is what the book says:
Repair Instructions
Body Control Module Replacement
Removal Procedure
Caution: Refer to Battery Disconnect Caution in Cautions and Notices.
1. Disconnect the negative battery cable(s).
2. Remove the knee bolster. Refer to Knee Bolster Replacement (Non Luxury) or Knee Bolster Replacement (Luxury).
3. Disconnect the brown connector.
4. Disconnect all other connectors (1).
5. Remove the BCM from the sliding bracket.
Installation Procedure
1. Slide the BCM onto the bracket.
2. Connect all the connectors (1) except the brown connector.
3. Connect the brown connector.
4. Install the knee bolster. Refer to Knee Bolster Replacement (Non Luxury) or Knee Bolster Replacement (Luxury).
5. Connect the negative battery cable(s).
6. Reprogram the BCM. Refer to BCM Programming/RPO Configuration.
Take care, Eggert
Old 03-20-2005, 12:05 AM
Obs
Thanks for the response, mine is the old body style.
John
Old 03-20-2005, 07:42 PM
777stickman 777stickman is offline
It's located under the center of the instrument panel. Look for 5 wires, Pink, Gray, Orange, Black & White. Two other things can be suspect also. The remote lock reciever (located just above the interior light module) and the headlight switch.
Hope this helps. My Sub is an old body '99 also.
Old 03-20-2005, 10:33 PM
instrument panel
Thanks,
it's not there, but I think this is what is going on. I have an alarm in this vehicle, probably not factory. the wire colors you mention lead to this unit (Kaiser VIP 4000), so maybe the lamp module was removed. I do have the remote function actuator module . what do you think?
Old 03-21-2005, 09:56 AM
I forgot to mention the door jam switches as a likely suspect also.
Try this:
1. Disconnect the head lamp switch and close the doors. If the lights go out, it's the switch or a door jam switch.
2. If they stay on, disconnect the door lock module. If they go out, it's the door lock module.
3. You may want to disconnect the alarm module also and see what happens.
There's also the possibility of shorted wires in the system.
Old 04-07-2005, 04:12 PM
YukonBlues YukonBlues is offline
Unhappy interior lamp
I am having the same problem. I replaced the interior headlamp switch and this solved the problem for about 5 days then the lights came on again. I am having to use the over-ride switch to turn them off.
Not sure what to do now........
Can anyone tell me where the door lock module is located?
Old 04-08-2005, 08:57 AM
Hi YukonBlues,
if it was good for 5 days after doing the switch then it is my suspicion that you moved something that went back to bad over time.
May be a wire touching another, a bad connection so the control module does not know to shut it off?
You have touched the problem spot. I hope you can find it.
Take care, Eggert
Old 04-08-2005, 09:24 AM
Re: Re: interior lamp control module 99 suburban
Well guess what, it started working again... Wonder how long this will last.
Old 04-08-2005, 08:00 PM
Thunderbolt Thunderbolt is offline
I doubt it is the module. There is a 99.9% chance it is one or more of the door switches. It is a commom problem on this body style gm truck. I have seen several with the exact same symtoms and not one of them was the module and all where switches.
Old 04-10-2005, 05:15 PM
more Blues
New problem, when I accelerate the engine is very hesitant. It’s like the engine is not getting enough fuel. Could all this be linked to the truck’s computer or brain box?
Old 04-10-2005, 10:27 PM
Hi Yukon Blues, please post your model and year.
This could be anything from a clogged fuel filter to ??? What maintenance or diagnosis has been done? Take care,Eggert
Old 04-11-2005, 07:33 AM
still blue
It is a 1999 Yukon SLT, 2WD, has always been meticulously maintained. The last time it was in shop (two weeks back), everything checked out ok. During that visit, an A/C modulator valve was put in.
Old 04-11-2005, 04:41 PM
Hi YukonBlues,
Are there any trouble codes stored?
I would go through fuel delivery and ignition procedures. Or have the dealer do it. This could be many things.
Take care, Eggert
Old 04-15-2005, 08:15 AM
Unhappy More Blues
Update – It was the fuel pump. So I have a new fuel pump and filter, also had the injectors cleaned. The dealer also checked all of the door switches and they were ok. They said it was the light control switch causing the interior light problem and I should have used a GM switch. Anyway, I let them put a new light control switch in… So $930 dollars later I am driving away from the dealer and the interior lights CAME ON AGAIN… I GIVE UP……..
Another thing I have noticed, the light switch stays illuminated all of the time.
