Old 03-18-2005, 08:00 PM
zbc1998 zbc1998 is offline
Engine knocking
Need some advice. Oil lines came loose and all oil drained out going down the highway. After getting it towed and oil lines tightened the engine knocks quite loudly now. Not sure what problem is i.e. blown head gasket, cracked head, or lifters. Any suggestions on possible problem or additive that can be used to quiet the knock just to get rid of vehicle? Thanks for the advice in advance
Old 03-18-2005, 08:07 PM
ricksza's Avatar
ricksza ricksza is offline
Re: Engine knocking
If it's knocking from lack of oil, most likely the rod bearings are worn or spun and the crankshaft is scored. You can try a heavier weight oil or a thick additive, though usually the noise won't totally go away especially when hot.
Old 03-18-2005, 08:09 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: Engine knocking
Did you continue to drive it without oil pressure?
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 03-18-2005, 08:11 PM
Re: Engine knocking
No pulled over immediately maybe .5 mile driven like that
Old 03-18-2005, 08:24 PM
BlazerLT's Avatar
AF -Advisor
Re: Engine knocking
Was the engine knocking when you pulled over?
Old 03-18-2005, 08:30 PM
Re: Engine knocking
Yes it sure was. Oil was bone dry had ran out from loose oil line by the oil filter. Tried putting oil in just to get it to the garage but upon starting all oil pumped right out due to the loose lines. Had lines tightened and oil level and pressure is fine but now the good old knocking
Old 03-18-2005, 08:32 PM
BlazerLT's Avatar
AF -Advisor
Re: Re: Engine knocking
Sorry to say, but I think your crank is toast bro.
Old 03-18-2005, 08:37 PM
Re: Engine knocking
I appreciate the info good thing I bought a new van the night before
Old 03-18-2005, 08:41 PM
BlazerLT's Avatar
AF -Advisor
Re: Engine knocking
Man, that is too bad too.
2000 as well. Real shame.
You can pick up another motor cheap though off of ebay and swap it right on.
http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WDVW
