Go Back   Automotive Forums Car Chat > Dodge > Daytona
Old 03-18-2005, 07:23 PM
Mopar87 Mopar87 is offline
How Hard/Much is it if I wanted a Turbo
I was thinkin of getting a Dodge/Chrysler/Plymouth Daytona/laser or maybe even a Le Baron.
I dont really want a standard and most Daytonas that have Turbos are standard. If I were to get an automatic then It will likely not have a Turbo.
I was wondering if anybody could tell me how much it costs($canadian) to add a turbo to a Daytona or Le Baron.
Does anyone have any good sites where I can find out how to add a turbo?
Old 03-21-2005, 02:11 PM
Azrael4h's Avatar
Azrael4h Azrael4h is offline
Send a message via ICQ to Azrael4h Send a message via AIM to Azrael4h Send a message via MSN to Azrael4h Send a message via Yahoo to Azrael4h
http://minimopar.knizefamily.net/
You should be able to just swap the computer, turbo, and other assorted parts off a turbo I or II car onto a NA one; though the suspensions may be quite a bit different. the Turbo III or IV I think had a stronger block than the T1 or 2 setups.
Guard: Where are you going in such a hurry?
Gorrak (the ranger): Uhhh...Gorrak have quiche in oven!!
Guard: well hurry along.
Old 03-22-2005, 12:09 AM
AWP9521 AWP9521 is offline
Re: How Hard/Much is it if I wanted a Turbo
If you want to swap N/A to Turbo you need to get the Engine too as well as the Electronics, Wiring, sensors and solenoids, and even a different Fuel Pump for the tank, plus the Turbo Tranny and Converter, Intermediate Shaft that bolts to the Block so you can run the Equal Length Halfshafts, I can go on. N/A Engines also have higher compression than Turbo Engines do by 1 or 2 points as well as different conecting rods, plus the block doesn't have the provisions for the water and oil return connections for the Turbo. Turbo Rods have an oil squirter on the big end to spray oil on the underside of the Piston to cool them, N/A Rods do not. They won't handle even moderate boost without something going or it detonating itself to ruins. There are plenty of Le Baron's and Daytona's out there with Turbo Engines and Automatic Trannys.
Old 03-27-2005, 11:04 PM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
Re: Re: How Hard/Much is it if I wanted a Turbo
Exactly, most of the turbo cars came with a Turbo I and the A-413 automatic. Don't waste the time and money to convert from TBI to turbo because it will require far too much of both. You would be much better off finding am automatic Turbo I car and doing a Turbo II conversion. I also suggest you take a look at the following website:
Donovan's Dodge Garage.
