Old 03-18-2005, 04:00 PM
nancyc nancyc is offline
Question EGR trouble code, where is it??
anyone know where this exhaust gas recirculation circuit is located on my car? 91 , 3.1? any sites online that i can ck out to see this and what it looks like?
can i replace this or repair it so as it wont stick open and cause trouble for me?
my diagn trouble codes showed this was what is wrong with my car.
thanks!!
Old 03-18-2005, 05:34 PM
jeffcoslacker's Avatar
jeffcoslacker jeffcoslacker is offline
Lactose the Intolerant
Re: EGR trouble code, where is it??
The problem with the ERG valve after reading your description of the problem is that the valve is not closing, allowing exhaust back into the intake at idle, effectively causing a massive vacuum leak. Usually the problem is that the plunger is crudded up to the point it cannot seal completely when it drops shut. It doesn't fully seat and leaks. The EGR is on top of the motor, right near the throttle body on your year, it is a round metal item sticing up and toward the firewall of the engine compartment. I wish I had one around here to take a pic for you, but mine is a different design. If you look up the part on AutoZone's site, I think they have a component location that will show you where it is on your car. Once you have found it, you might just be able to take it off (real easy) and clean the seat so it works correctly. I would try that first before replacing it.
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
Old 03-19-2005, 02:42 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
hey jeff, cool animation on your posts. I agree with you that the EGR could just have a piece of carbon in it and cleaning it will fix the problem. Also check the passages in the Throttle body and intake for carbon, as a restricted passage will trip an EGR code as well.
