Old 03-18-2005, 12:53 PM
slayme01 slayme01 is offline
Dash Dummy Lights
On my 95 Talon TSi, I replaced my steering wheel.That caused the SRS light to come on. I took it to my mechanic but they could not clear it out
They asaid it could not read it.How can I turn off the light.
Another light is the coolant temp,I repaced the coolant tank but the light still stays on. Yes, the coolant is full everywhere.Can I somehow
turn that off(pull a fuse or something?)
Any help would be cool.
Old 03-18-2005, 02:18 PM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
Re: Dash Dummy Lights
I would assume that the SRS light is on for a reason and being a safety issue you should probably determine the problem instead of just turning off the light. But, I guess you could pull the bulbs at the back of the cluster.
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 03-18-2005, 04:00 PM
96spyderman's Avatar
96spyderman 96spyderman is offline
Send a message via AIM to 96spyderman Send a message via MSN to 96spyderman
Did you replace the steering wheel with an aftermarket one?......
As for the coolant light.... have you checked the coolant temp sensor?
I agree... just pull the bulb out from the back of the cluster.....
"A man's greatest work is to break his enemies, to drive them before him, to take from them all the things that have been theirs." -Ghengis Khan
Old 03-18-2005, 07:51 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
if you don't really worry about the srs light too much, pull it out but DO NOT pull out the coolant light. that could save you a motor in a bad instance. have you tried re-setting the codes with a scanner or just reading them through the car's own system. you might have to have them cleared with a scanner.
95 Talon TSI AWD
97 Eclipse GST
Old 03-19-2005, 08:44 PM
macder macder is offline
Send a message via MSN to macder
I'm thinking it's b/c the ecu cannot detect the streering wheel air bag since it is not there no more. Figure out where the sensor, or cable for it is and try to complete the circuit somehow to fool the ecu. I don't have air bags in my car, but from what i know the SRS light has something to do w/ the airbag. Or like everyone else said, pull the bulb which would be the "I'm lazy" quick fix which is perfectly fine for this problem.
1993 Eagle Talon ES (4g63NA)
14.6 @ 98 mph (110 octane race fuel)
-5 Speed Transmission (From a 4g67)
-Stage 2 Crane cams
-Ported and polished head
-Aggresive valve springs
-2.5" Custom made exhaust piping
-Custom header
-Gutted catalytic converter
-Bored 0.5mm
-Advanced ignition timing (CAS) aprox. 5 degrees (set @ ~10deg BTDC)
-2g valve lifters (Lifter noise returned, now it a true DSM)
-K&N w/modified air canister
