Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 03-18-2005, 12:46 PM
evilbeef evilbeef is offline
vtec controller
I was looking at vtec controllers for my 97 civic ex i was wondering if anyone has hooked one up and how hard it is.
Old 03-18-2005, 09:34 PM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
Re: vtec controller
if you know how to cut a wire and solder, then you wont have a problem.
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 03-20-2005, 12:19 PM
snowman2005's Avatar
snowman2005 snowman2005 is offline
Send a message via AIM to snowman2005
Re: vtec controller
dont get one unless u have major engine upgrades and i dotn mean just i/h/e
Old 03-20-2005, 12:47 PM
240SXLude 240SXLude is offline
Re: vtec controller
I heard it can actually slow ur car down if u set it at lower rpms. DUn kno if its true.
Old 03-20-2005, 01:11 PM
Re: vtec controller
ya because the higher lift is designed to make more power in thehigher rpm. honda set their vtec right where it should be.
Old 03-20-2005, 01:33 PM
SiGNAL748's Avatar
SiGNAL748 SiGNAL748 is offline
Send a message via AIM to SiGNAL748 Send a message via MSN to SiGNAL748
i doubt a vtec controller would make much of a difference in a sohc civic anyway.
Old 03-20-2005, 03:59 PM
greenmonkey's Avatar
greenmonkey greenmonkey is offline
Re: vtec controller
vtec was designed to give best of both worlds, good low rpm gas milage and high end performance. i forget who it was, but a member on the boards set his vtec to 2500 rpms, but it would only engage the larger lift if the throttle was more than 3/4 open. so if you were to do anything do something like that, so you can keep good milage but still have the power on tap when you need it. but as to the original question, i have no clue.
Old 03-20-2005, 08:29 PM
Privatebigandrew's Avatar
Privatebigandrew Privatebigandrew is offline
Send a message via AIM to Privatebigandrew Send a message via Yahoo to Privatebigandrew
Re: Re: vtec controller
Only certain VTEC systems were designed for this, like the SOHC versions. DOHC VTEC engines are for performance only. Some VTEC system actually improve gas milage when they kick in. Anyhow, A VTEC controller is absolutley pointless unless you have internal work, cams or some other major modification and a dyno to tune it. I think that Honda pays there engineers plenty of money to set VTEC activation at the optimal point and someone just going an changing that point is ridiculous. I thinc those controllers are the biggest scam i the import market. Even if you really did need one, you can make one yourself simply with a switch and a shift light.
94' Del Sol VTEC (B16A3) SOLD.
Accel plug wires, NGK iridium IX plugs, AEM short ram intake, DC sports ceramic coated header (4-2-1), Airmass high flow cat ,Custom Magnaflow exhaust, Bosal Brospeed tips, Neuspeed short throw shifter, Tokico clutch master cylinder, Tokico clutch slave cylinder, Prothane complete kit bushings, Brembo front rotors, NR EL-Glo instrument gauges, CTR LSD trans with ITR final drive, Exedy chromoly flywheel, ACT HDSS clutch kit, Raxle axles.
Old 03-21-2005, 01:31 PM
Ace$nyper's Avatar
Ace$nyper Ace$nyper is offline
Banned
Send a message via AIM to Ace$nyper Send a message via MSN to Ace$nyper Send a message via Yahoo to Ace$nyper
Re: Re: Re: vtec controller
