Old 03-18-2005, 11:47 AM
devaney devaney is offline
clock, dome light problems
I turned off the dome light yesterday while i was working on the car. When i went to turn it back on this morning, it was dead. When I turned on my car, my clock was super dim and the time was way off. I flipped off the headlights and turned them back on and then the clock went dark. After several minutes it came back on, but dim again. Long story short, it eventually went dark, it kept keeping time, but could only be seen dimly when you pressed one of the min, hr, or reset buttons. Then it reset itself again an hour later and then started working again dimly. I'm thinking a fuse, but then I don't think the clock would kind of be working. It's almost like it's just not getting enough power or something or intermittenly (sp) at times. I checked the back of the clock, and it's plugged in and all...
Also, what's the bingham electrical website address? I did a search of "bingham" but it didn't return any results.
Thanks in advance.
Old 03-18-2005, 03:10 PM
Scott82 Scott82 is offline
Re: clock, dome light problems
Finally found it. I need to write this site down so i don't have to search for it when i need it too. good luck man
http://www.binghamtonlife.com/manual...electrical.htm
Old 03-18-2005, 03:32 PM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
What exactly did you do to your car?
ZC stuff
http://dh-racing.com
http://www.thezcr.com/html/zcbook.php
http://dmoore.com/crx/zc.htm
http://www.jgenginedynamics.com/HOME%20PAGE
http://www.theoldone.com/
Old 03-18-2005, 06:52 PM
lol, good question!
if you're asking why i turned off the dome light in the first place it was because i was replacing the door panels and the doors were wide open while doing so, so i switched it off. i was also messing around with the instrument panel (i pulled it all the way out, and then plugged it all back in. it all works fine though).
i found a blown fuse which is the one for my door buzzer. the link above does not work for me. is this the same fuse that controls my dome light and clock?? maybe my clock is dying and the light to the dome light is out?
Old 03-18-2005, 07:31 PM
Ones&zeros Ones&zeros is offline
Send a message via AIM to Ones&zeros
go to the junk yard and get a new clock.
Old 03-18-2005, 08:56 PM
kelrx8-civicbeater kelrx8-civicbeater is offline
Send a message via AIM to kelrx8-civicbeater
when I first got my car the clock was off
till i held down the reset button then it would read 12:00 but when i let go of the button it would shut off same time dome light would not work.look under dash and there were a bunch of blown fuses.
