Go Back   Automotive Forums Car Chat > Honda > Integra
Old 03-17-2005, 11:25 PM
autoenthus3 autoenthus3 is offline
Send a message via AIM to autoenthus3
clicking
hi have a 97 GSR and i was wondering how big of a problem a lifter would be to fix in the b18c1
Old 03-17-2005, 11:55 PM
whtteg's Avatar
whtteg whtteg is offline
Send a message via AIM to whtteg
Re: clicking
Your car does not have push rods so you have no lifters. You just have a rocer arm that rides on the cam itself. If you are having clicking sounds or tapping sounds then you prob need a valve lash adjustment.
Old 03-18-2005, 10:33 AM
where would i get that done? (i just bought this car two days ago)
Old 03-18-2005, 12:44 PM
Si Integra Si Integra is offline
Send a message via AIM to Si Integra
Re: clicking
Any automotive shop can adjust the valve lash. It is actually a fairly easy "do it yourself" fix.
The dealer is always the best place as they have the majority experiance, but any quality mechanic will do just fine
Old 03-19-2005, 07:05 PM
well how bad of a problem is this? will it hurt anything? should i not rev high or should i not drive it long? what? i work at a small shop and i havent heard of it and neither has the other mechanics. and if its not a big deal how would i do it?
Old 03-19-2005, 07:27 PM
Re: clicking
do you have to adjust them with a special tool or can u adjust them with a offset rench and a screw driver?
Old 03-20-2005, 11:06 AM
Re: clicking
You simply need a feeler gauge, a wrench and screw driver. Some people use assembly lube as well. The engine must be cold, or you will not set them correctly.
Purchasing the helms manual or atleast the chiltons/haynes will explain how to do it.
Old 03-23-2005, 06:31 PM
Re: Re: clicking
We have alldata at work
Old 03-25-2005, 09:57 AM
Re: clicking
all data should do just fine.
