fuel filter choice
Need to buy a new fuel filter tomorrow, looking at Nippon ($29), Bosch ($21), or whichever they are selling at 3sx for $27. I see no problems going with the $21 Bosch from thepartsbin...do you?
http://oem.thepartsbin.com/parts/the...rt=Fuel+Filter http://www.3sxperformance.com/fuel.asp
96 3000gt vr4 -K&N FIPK -Proboost mbc -Cusco front + rear strut bars -Greddy type-s -ATR downpipe -no cats -15Gs, 3sx aluminum pulley, FMIC, SAFC, walboro pump, EVO 560ccs, and Meth Injection Kit all waiting to go in shortly. Your 1996 Mitsubishi 3000GT VR-4 is the 92nd out of the 315 that were made that year. Only 21 of which are exactly identical. |
Re: fuel filter choice
I think a filters a filter as long as its from a name brand, which bosch is.
1995 3000GT VR-4 Installed: ESP front precat eliminating downpipe, test pipe, RF-1008 K&N, Dejon tool Y pipe, 1G DSM BOV, MSD wires, Guted rear pre cat, ISSPRO EV Marine boost gauge, IPO MBC, EGR blockoffs, Palm m515 dataloger setup, NGK iridium plugs, SPEC stage II clutch 500ft/lb, 5300k HID plug and play setup. Soon:Topline Engineering ground wires. |
Fram is usually pretty good.
I'm talking fuel filters, not oil filters, but Fram's oil filters pretty much suck, so I'm steering clear of them.
You should check this out: http://www.frankhunt.com/FRANK/corve...html#fram-ph8a http://www.shoclub.com/lubrication-o...n-oilpart5.htm
So which oil filters do you use?
I have used napa in the past, they are cheep lol. From now on I think I'll use Mobil-1 or Bosch.
Where do they sell Mobil-1 filters? I've only seen Fram and Bosch.
It says on the site that they can be had at walmart or autozone, there are lots of different filters at autozone.
Back on topic.. I think that Bosch would be fine, its not like most people change their filter anyways because gas is pretty clean.. lots more clean than guky oil thats always being recycled and degraded.
Igovert, i'm happy with my Bosch fuel filter from thepartsbin.com.
as far as oil filters, go with WIX, they're the best, recommended by mechanics.
93 3000GT base K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2 coming soon: adj. cam gears | bi-xenon HID retrofit |
I ordered the bosch a few hours ago
Where is the fuel filter located? Somwhere near the battery?
There is a link with pictures and instructions in the FAQ...I think it was from stealth316, but I don't remember.
I think it's under the battery maybe.
