Old 03-17-2005, 06:16 PM
94accordlx1 94accordlx1 is offline
valve ticking
can anyone tell me how to fix this?
Old 03-17-2005, 07:08 PM
cbeck cbeck is offline
Re: valve ticking
You've checked the oil level?
I'm not a mechanic, I'm the guy people bring their car too when they don't run. I usually scratch my head and tap on stuff, then call the dealer to see if they can help me find the carburetor.
Old 03-18-2005, 02:15 AM
mpumas mpumas is offline
Re: valve ticking
You only have one ticking? When was the last time you did a valve adjustment?
Old 03-18-2005, 11:17 AM
blacknight's Avatar
blacknight blacknight is offline
At a certain amount of miles, (over 50K) 4cyl accords are known for valve tapping.
You can use some STP oil treatment. It's about $3 from Pep voys or Autozone. That should rectify the problem. Use it after each oil change.
It provides extra lubrication during start ups where valve tapping is most common
what's that red button on your steering wheel.......OOOHHH MMMYYY GODDDD :22yikes:
Old 03-18-2005, 09:14 PM
well my car has 195000 miles on it. How much should a valve adjustment cost? My friend told my that any additives never work. Said there are used just to make you feel better. it sounds like more than one of them are ticking
Old 03-18-2005, 09:21 PM
Re: valve ticking
About 1 hour of shop labor.
Old 03-18-2005, 09:24 PM
Re: valve ticking
Don't use STP oil treatment. It is motor honey and increases the viscosity. Honda recommends valve adjustments about every 45K miles.
Old 03-18-2005, 09:57 PM
should i use motor honey then, and get a valve adjustment? What do they do with valve adjustment do they install new valves ??
Old 03-19-2005, 02:55 AM
Re: valve ticking
Don't use motor honey. Valve adjustment is a process of adjusting a screw on the rocker arm above each valve so that there is a set clearance between the valve top and the rocker arm when the engine is cold and the valve is closed (TDC for that cylinder. ) Requires a wrench, screwdriver and a feeler guage.
Old 03-19-2005, 01:39 PM
ight thanks so now i know what to do so i dont get riped off
