'85 century, can seem to get it right
Okay, bear with me.
85 century, 4cly, throttle body. When we got the car ran good, after a day it had some running problems, step on the gas and it sputters, put new plugs, wires, cap rotor on, still sputtered. I saw fuel leaking from the carb, took it off and put a new gasket on the bottom to the intake manifold. The carb had a very lot of carbon blocking several of the air, fuel chambers. Cleaned it up, put it back to gether, still sputter, but running a bit better. Put a new map sensor on, still sputtering. What am i missing..?? |
Re: '85 century, can seem to get it right
Okay, i took the car down to a shop and had them read the OBD1 codes. 13,21,22,33,34,42,44 were the codes active at the time, can anyone recommend a site to look up the obd codes..?? 2 of those were o2, and 2 were tps. Guess i can start with a tps sensor. |
Check for a vaccume line off, The Iac valve on the throttle body might also need cleaning or replacing. Air filter, fuel filter, and test your fuel pump.
Now remember, I like most people on this site are not master mechanics. These are places I would start on my own car. My advice cost you nothing but, maybe some time. If it's right or wrong please report back so someone else (maybe even me) will know where to look if I/they have the same problem. Good luck |
