Old 03-17-2005, 03:26 PM
nancyc nancyc is offline
got the code info
mannyboy or anyone else,
i did the diagn. code test again. and it showed me the number 32. which is EGR, exhaust gas recirculation circuit... anyone know what that would mean? and how or what i can do to correct it? my car is a 91, 3.1 with 128K mi on it. exempt from emissions due to less than 5K mi a yr on it
nancyc
Old 03-18-2005, 05:56 AM
jeffcoslacker's Avatar
jeffcoslacker jeffcoslacker is offline
Lactose the Intolerant
Re: got the code info
If that is the only EGR fault it can indicate (I know the later ones can sense positioning problems to a point) then the EGR might not be opening. If it was sticking open, you'd have issues with poor idle, possibly stalling on throttle drop (like coming off the highway, or dropping the throttle abruptly after acceleration)
I know the EGR was a common source of problems on the older 2.8's and 3.1's, so it wouldn't suprise me if it was going bad.
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
Old 03-18-2005, 07:47 AM
thats exactly what my car is doing.. i cant believe it!!!! it idles horribly, like shakes and it has stalled a few times. at one point the RPM needle dropped to 0 while i was at a lite but car was still running. then needle went up when i accelerated to go..
now i have to find out where this circuit is and replace it.
