Go Back   Automotive Forums Car Chat > Ford > Contour
Old 03-17-2005, 01:16 PM
JimR's Avatar
JimR JimR is offline
PCV Valve help
ok im having some probs with finding the pcv valve. i have a 96 4cyl. i have been told i have to remove the (Cat) to replace it. i want to replace it because the car now has 85k miles and runs real cold. its not the cooling system because i have a new set of hoses, waterpump, and thermostat. i thinking that maybe its pumping in too much exhost gas in to my cylenders. i also have less power then what i started with and a real bad idle.
if u think its no the valve then plz tell me what u think or if u know how to get out the pcv.
thanks
Old 03-17-2005, 01:22 PM
Jason43's Avatar
Jason43 Jason43 is offline
Re: PCV Valve help
If you had a V6 I could tell you. Since you don't, the only advice I can give is go do a search in the Zetec Maintenance forum at contour.org.
Just go to contour.org
1999 Ford Contour SVT
Old 03-17-2005, 03:19 PM
pre98zetec's Avatar
pre98zetec pre98zetec is offline
Send a message via AIM to pre98zetec Send a message via MSN to pre98zetec Send a message via Yahoo to pre98zetec
Re: PCV Valve help
PCV valve is behind the exhaust manifold on the zetec.
-Josh-
96' Integra GSR / ITR cams/valvetrain. Skunk2 IM, Greddy evo2, AEM CAI, RMF Header, Megan testpipe, Hasport mounts, Eibach coilovers, Beaks tie bar, Megan H brace, Rota Attacks, F/R strut bar, Kirk 6 point cage, Bride Cugas, Takata 4 Point, ITR Steering wheel
98' SVT Contour, 3L Port-Matched swap with SVT cams/full bolt ons; 224fwhp.
01' Chevy Blazer, DD.
Old 03-19-2005, 12:56 PM
JimR's Avatar
Re: PCV Valve help
thx found it
stupid place if u as me
