Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > Maintenance
Maintenance problems, fixes.
Old 03-27-2002, 02:19 PM
GoodJuan's Avatar
GoodJuan GoodJuan is offline
Send a message via AIM to GoodJuan
Unhappy Hand brake light stays lit
It used to stay on for a little while after starting it, then it would turn off after a few minutes. Then it started coming on during hard acceleration. Now it's just on all the time. Anyone have a similar problem or know how to fix this? Thanks.
They should have kept Dr. Katz on the air.
Old 03-27-2002, 06:03 PM
AznVirus's Avatar
AznVirus AznVirus is offline
Send a message via AIM to AznVirus
you dont have enough brake fluid in the master cylinder, check it first. cause under hard acceleration, the fluid sensor thought you didnt have enough, just add some more brake fluid. its not always the hand brake thats the problem. check all your brake lines for cracks or leaks.
1.6 - The Underdog
GA16DE-T Club!
Old 03-30-2002, 04:46 AM
nismo_gt's Avatar
nismo_gt nismo_gt is offline
if its a P10 then it could just need the handbrake switch (for the light)
adjusting, its not uncommon.
Primera GT
Old 03-30-2002, 02:28 PM
Yahnozha Yahnozha is offline
Send a message via Yahoo to Yahnozha
Ditto, same problem affected me...that sensor for the brake fluid is really sensetive...just top it off...
P@ - www.customsteel.com
Red 99 G20(t) / UR 2 piece / JWT POP / HS CAI / WW Lip / HS Header / Greddy Evo / S3 cams
Old 03-31-2002, 04:02 AM
GoodJuan's Avatar
yup, it was the sensor. Just topped it off and light's now off. Thanks everyone, this board is awesome.
