Old 03-17-2005, 11:16 AM
1stgen gsx 1stgen gsx is offline
Send a message via Yahoo to 1stgen gsx
Angry Car not working after timing belt change
ok well like i have been having trouble with my damn car i just changed the timming belt on the damn thing. I even put the timming on right and made sure that the 1st cylinder is tdc and still the damn thing wount start it started fine before i changed the belt but i had to change it because there where cracks in the belt. i have the chillton book and i read that damn thing and did what they said to do and still no luck . Did anyone have this same problem if so can you help me i really need the help this is pissing me off already and i need my car i havent been driving it for 4 days already and im going in withdraws so can someone help me plz.
Old 03-17-2005, 11:26 AM
ted_ex's Avatar
ted_ex ted_ex is offline
Does the engine turn over? If it does, does it sound right? A lot of people (me) put the timing exactly 1/2 off because the cam gears are marked poorly. If it makes a hollow thumping sound when it turns over it's probably that. If it sounds ok sometimes holding the throttle open when starting the car will help clear the combustion chamber of built up gas fumes which inhibit combustion.
Old 03-17-2005, 11:53 AM
Re: Car not working after timing belt change
man the car doesnt even sound like it wants to turn over i dont know why you can see the cams turning but the car wont start
Old 03-17-2005, 05:50 PM
1g90gsx's Avatar
1g90gsx 1g90gsx is offline
any time you do a timing belt change you ALLWAYS TURN IT OVER BY HAND FIRST TO SEE IF IT BINDS UP AND MAKE SURE THE MARKS LINE UP.if its off more than a tooth and you do not turn it over by hand and just try to start it will result in bent valves period.
1990 MIRAGE HB
4G SWAP
FMIC
ACT 2100
TIAL BOV
TIAL WASTEGATE
FIC 650"s
SX AFR
MAFT
INNOVATIVE DUEL BB TURBO
TURBONETICS MANIFOLD
255 PUMP
WISECO 8:51
EAGLE RODS
DELTA 272 CAMS
SETRAB OIL COOLER
AEROMOTIVE STARLITE HOSE
AUTOMETER
ROTA CIRCUT 8"S
Old 03-17-2005, 10:38 PM
EVOclipse EVOclipse is offline
Send a message via AIM to EVOclipse
did u make sure u installed it in the right direction? i dunno ive been reading alot on this since im about to do a headgasket and in the haynes manual they were pretty anal about making sure u alight it a 1/2tooth before tdc, and making sure it was installed in the right direction. thats all i can think of gluck
240sx, soon to be S13.5, future mods are wheels and hopefully paint and the rest of my conversion.
(96 eclipse RS 5-speed, magnaflow exhaust,chrome headers,cold air intake,denso iridium sparkplugs,new kumho tires )******EDIT totalled car now*******
Old 03-18-2005, 09:08 AM
hey you know what i was on vfaq and they show the cam sprockets up close with the exuast cam with the bigger mark and the intake with the little mark. I checked my car and i had them switched this intake with the big mark and the exuast with the mittle mark so i hope this fixes my problem. Do you think that could be my problem?
Old 03-18-2005, 11:05 AM
kjewer1 kjewer1 is offline
AF - Advisor
Just make sure the cam dowel pin is at 12 oclock when the marks are lined up. The marks will still ine up with the cams at 6 oclock. I would highly recomend doing a compression test either way. It will tell you right away if you bent valves. Additionally, if someone doesnt know how to set the timing properly, odds are the tension was set incorrectly too. After rotating the motor clockwise stopping on the marks, Make sure the gap between the tensioner body and tensioner swing arm is between .15 and .18 inches, or 5/32nds and 3/16ths (to use drill bits or allen wrenches). Also verify that the ignition timing is still set properly (search for the procedure, if its not in your manual) since it is indexed off of the intake cam.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
