Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 03-17-2005, 10:30 AM
GsT Pimp Juice GsT Pimp Juice is offline
Twin Turbo
is it possible to twin turbo my 95 eclipse gst? also whats a safe amount of boost to run on a stock eclipse gst?
Old 03-17-2005, 10:58 AM
Shpyder's Avatar
Shpyder Shpyder is offline
Moderate moderator
Re: Twin Turbo
"Twin turbo" is more a cool sounding word, that it is an efficient turbo setup for Eclipses. you can skyrocket hp figures with a single turbo on our cars. No need fo tt. Search...your question has been answered many times before.
The daily driver. The weekend cruiser. The lazy shop hog.
Old 03-17-2005, 11:41 AM
shadow eclipse shadow eclipse is offline
Send a message via AIM to shadow eclipse
Re: Twin Turbo
This has already been dicussed!!! No its not worth it!! Please, please, please!! Do a search!!
95 GSX 14.748
90 GSX
Old 03-17-2005, 04:09 PM
96spyderman's Avatar
96spyderman 96spyderman is offline
Send a message via AIM to 96spyderman Send a message via MSN to 96spyderman
Re: Twin Turbo
I'm pretty sure for a T25 turbo 15-16 psi is a safe # otherwise the turbo's life will start to dump somewhat quickly...
And yes the twin turbo has been discussed many times....
Twin turbos are for if you have a V6 or V8 where you have two exhaust manifolds.......and then you have the problem of one working more or less than the other and twice as hard to tune... thats what I remember reading about the 3000 VR4 anyways....ooooh a boat with 2 turbos!!! lol
"A man's greatest work is to break his enemies, to drive them before him, to take from them all the things that have been theirs." -Ghengis Khan
Old 03-17-2005, 05:29 PM
bighauns's Avatar
bighauns bighauns is offline
Send a message via MSN to bighauns
Re: Twin Turbo
yeah, most definately not worth it at all. this has been discussed a lot, feel free to do a seach, but i wouldnt waste my time, just leave it at the fact that it is not worth it.
"You can have everything in life you want if you will just help enough other people get what they want."
Old 03-18-2005, 05:02 AM
TreeFrog's Avatar
TreeFrog TreeFrog is offline
Send a message via AIM to TreeFrog
Re: Twin Turbo
stupid, do a search. there is NO POINT of a twin turbo on an eclipse.
Something new is coming...
Old 03-29-2005, 04:00 AM
Kuhn's Avatar
Kuhn Kuhn is offline
Send a message via AIM to Kuhn Send a message via Yahoo to Kuhn
Re: Twin Turbo
Yeah, I can't see a point to having twin turbos on most 4cyl. It's been done though... I guess the benifit would be that 2 smaller turbos working together could flow as much air as a larger one, but with less time to spool... Also, a smaller turbo could be used in conjunction with a larger one to help spool the larger turbo sooner... and make the hp curve a little more linear.
Overall... it's retarded!! ...A waste of money and time. :-D
Old 03-29-2005, 07:16 AM
cursed1g cursed1g is offline
Banned
Re: Re: Twin Turbo
Stupid? yea way to go......... NOT !!! anyways not u dont need a twin to make alot of power, but it would be differnt and its possable. and if you do try this make sure you use 2 small turbo's wich will make alot less lagg
Old 04-02-2005, 05:07 AM
Whathits14 Whathits14 is offline
Re: Twin Turbo
Twin turbos were most manufactures way of getting a 6 cyl car faster without dumping lots of cash into it. The fastest supras (well, fastest anything turbo car) in the world run on a single turbo. I did see a TT honda once, but it was more the novelty that struck me than the power.
Stock t-2small can do 16psi, but anything above that and you wont make power, infact you can push the turbo to hard, to the point where it will actully have the compressed air so hot, that the heat of the air doesn't make up for the extra pressure. Lower your intake temps are, the more power you will make.
Instead of doing something stupid like TT'ing a eclipse, which would cost well over 2k, you can take that money, put a full garrett on with some fuel mods and a dece exhaust and you can run lo 12's.
As a side note, a lot of people think that they will make mad power just by putting on a FMIC. This will actually make less power than the stock SMIC with a t-25. The t-25 does not flow enough cfm's to make use of a fmic, and so the air stagnates there longer than it would if it had a bigger turbo. The FMIC is only nessecary when you upgrade your turbo. A t-25 will NEVER really need a fmic. You need a FMIC when you get heatsoak on your small smic. I don't think i've ever heard of a t-25 heatsoaking a sidemount...
Old 04-02-2005, 05:33 PM
97_3clipse's Avatar
97_3clipse 97_3clipse is offline
Send a message via AIM to 97_3clipse
Re: Twin Turbo
1998 Eagle Talon TSi AWD
6 Bolt Swap \ DSMLink V2.5 \ ACT 2100 clutch \ PTE SCM 61 \ Forge MBC@28psi \ VPE O2 Housing \ MR Downpipe \ Thermal R&D Cat-Back \ Tial 38mm WG dumping off O2 \ FMIC w\ in short route \ AFPR setup/walbro 255hp \ PTE 880cc injectors \ Crower Ti retianers \ Crower Springs \ Crower 64414 (stage 3 race) cams \ Ferrea valves \ 3.5 bar MAP \ PLX M-300 Wideband
Old 04-02-2005, 07:48 PM
Gsx_hooptie Gsx_hooptie is offline
Not that we've established that tt's suck on an eclipse, I have a question about tt'ing an inline engine. How the hell does that work? On a v-6 I figured you ran a turbo along each of the two manifolds for a tt, and on a straight 4/6 you run them in tandem?
I used to own a DSM.
Originally Posted by Anon.
Capitalization is the difference between, "Helping your uncle Jack off a horse," and, "Helping your uncle jack off a horse." The comma is the difference between, "Eats shoots and leaves," and "Eats, shoots, and leaves."
Old 04-02-2005, 08:02 PM
viet_boiiiii's Avatar
viet_boiiiii viet_boiiiii is offline
Send a message via AIM to viet_boiiiii
Re: Twin Turbo
dam u guys he only asked 2 questions. You guys have more sense than making fun of him, just answer it. Yes its possible to run TT but who wants to and stock t-25 can run up to 15-16 safely.
new 2006 Scion tC - 5spd
-magnaflow catback
http://www.cardomain.com/ride/2088489
~~~R.I.P (7-2-05)~~~
1998 Eclipse Gst - 5 spd
