Old 03-17-2005, 08:30 AM
turtlecrxsi's Avatar
turtlecrxsi turtlecrxsi is offline
Send a message via AIM to turtlecrxsi
broken exhaust manifold stud from d16a6
I don't understand why it would cost $125 bucks just to remove a header to back off a broken stud which isn't flush with the head. The local Honda mechanic said there is no exhaust leak to speak of even though I can feel some air there... maybe I'm just sensitive. Anyway, my car seems to run okay, but I may try removing that stud at some point in the future. Are exhaust manifold studs expensive? Is this something I should worry about? I'm starting a new job the week after next and will have to commute a good 40 miles to and from work each day.
2008 KIA Spectra5 SX
2010 Honda CR-V EX
Old 03-17-2005, 09:44 AM
CBURKE's Avatar
CBURKE CBURKE is offline
Re: broken exhaust manifold stud from d16a6
hahaha, i can help with this one. I just had to replace all my studs in my mitsu. 2 of them broke and were striped out and the others just were old. So i orders a set of stanles steel ones from slowboy racing.com and they are great!!!
now you can go to your local LOWS or HOME DEPOT and go to the bolt sec and you will see they have some that are already cut and good to go. I had to get some bigger ones from LOWS because the 2 were striped. Get a grade 5 bolt, that is the best they have and that should be good enough.
Now to get the old one out if you can't put 2 nuts on it you will have to get a metal drill bit not to small because it will brake. Drill a hole in it about half way or a little less. Go to the auto parts store and get a tool that looks like this.......
then when you drill it, it will exstract it the other way and taadaa out it will come. The threds are like a screw going the wrong way, so as you drill in it drills out. see what i am saying?
98 MITSU GST, 1990 TURBO MOTOR
98 ACURA INTEGRA LS
88 HONDA CIVIC HB
97 HONDA CBR 600
91 HONDA CRX DX
89 JEEP
Old 03-17-2005, 10:21 AM
Thanks. I understand what you mean. My buddy has an easy out but not a small enough bit. One of the studs on the other side of the head came out cuz the bolt was seized to it, but I managed to just put the whole thing back in. Maybe this is a hint to go get a y8 head...haha... Thanks again, CBURKE!
2010 Honda CR-V EX
Old 03-17-2005, 10:27 AM
CBURKE's Avatar
no prop
98 ACURA INTEGRA LS
88 HONDA CIVIC HB
97 HONDA CBR 600
91 HONDA CRX DX
89 JEEP
Old 03-17-2005, 01:39 PM
1PhatCX's Avatar
1PhatCX 1PhatCX is offline
if its just the threads that are snapped off, try to get a small pipe wrench on it!
works when i brake studs off
Old 03-17-2005, 02:12 PM
Okay, I'll try it. BTW, what's a pipe wrench.. a monkey wrench?
2010 Honda CR-V EX
Old 03-17-2005, 02:33 PM
YZ125rider21's Avatar
YZ125rider21 YZ125rider21 is offline
Send a message via AIM to YZ125rider21 Send a message via Yahoo to YZ125rider21
lmao a pipe wrench what plumers use and a monkey wrench(cresent wrench) is what mechanics use...hope this helps...lol
90 Honda CRX Si
-Red/Black
-B20B/b16
-AEM CAI -/\- Apexi GT Header/2¼" Custom Dynomax Exhaust
-Tein SS CoilOvers with pillow ball monuts -/\- ST Swaybars/Energy Suspension Bushings
-16x7 Lightweight Rotas -/\- Pro Stop Rotors -/\- Goodridge S.S. Brake Lines
-Skunk2 Shifter -/\- MoMo Steering Wheel
Old 03-17-2005, 03:49 PM
CBURKE's Avatar
Yeah but you may spend more time and may mess something up trying to fit that big ass wrench in such a tight spot.
98 ACURA INTEGRA LS
88 HONDA CIVIC HB
97 HONDA CBR 600
91 HONDA CRX DX
89 JEEP
Old 03-17-2005, 06:12 PM
1PhatCX's Avatar
Re: Re: broken exhaust manifold stud from d16a6
they have small ones, they work wonders
Old 03-17-2005, 10:26 PM
88CiViC_D-15's Avatar
88CiViC_D-15 88CiViC_D-15 is offline
Send a message via AIM to 88CiViC_D-15 Send a message via MSN to 88CiViC_D-15
i would say both ways would work, but the way CBURKE said to do it, i think would be the easyest way to do it. they work great
Team Lonely Drivers IS LOOKING FOR MORE MEMBERS,CLICK HERE
TLD FOURMS
- 88 civic std w/ sohc zc swap
- 88 integra ls, stock
- lookin for a 4dr. runnin or not
Old 03-18-2005, 11:37 AM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
or weld onto it and turn it out from there.
ZC stuff
http://dh-racing.com
http://www.thezcr.com/html/zcbook.php
http://dmoore.com/crx/zc.htm
http://www.jgenginedynamics.com/HOME%20PAGE
http://www.theoldone.com/
