Old 03-17-2005, 09:00 AM
5thGenAccord's Avatar
5thGenAccord 5thGenAccord is offline
Send a message via AIM to 5thGenAccord
Got A Check Engine Light
just driving this morning and the check engine light just came on. can someone tell me how to find out how to read the ecu or how to find out what it is?
i tried searching for the thread but for some reason the page wont come up. can someone point me in the right direction?
Old 03-18-2005, 10:14 PM
94accordlx1 94accordlx1 is offline
When was the last time you changed the spark plugs and the oxygen sensor on the car ?
Old 03-19-2005, 03:21 PM
mpumas mpumas is offline
Re: Got A Check Engine Light
You can change the plugs but I recommend not changing any mechanical parts until you read the stored ECU code that caused the light to come on in the first place. I hear Autozone will hook up the reader and tell you the code for free. Normally the ECU is under the passenger kick panel. I do not know where the service connector for your model is but Autozone does.
Old 03-19-2005, 09:21 PM
lorunner lorunner is offline
The scs is by the passenger kick panel. 2 pin usually blue
Stop asking me about radio codes I cant get them anymore!!!
Old 03-20-2005, 09:23 AM
what year is your car? Autozone only does that for model year 1996 and up.
Old 03-21-2005, 09:41 AM
Igovert500's Avatar
blue + red light magnet
If you have an OBDII (96+) most Autozones have a service where they will plug in a scanner to your ECU and retrieve the codes for free. If you don’t have this service available at your local Autozone, or you don’t have a local Autozone, or you have a pre-96 car, you will need to pull the code yourself. (You can take it to a dealership to have them pull the codes, but personally, I can think of a thousand better ways to spend $70/hour).
To learn how to pull your own codes, go here and read everything:
http://www.hondapitstop.com/accord/t...ror_codes.html
If for some reason that isn’t sufficient for you, you may want to look at this:
http://www.automotiveforums.com/vbul...em+malfunction
Now you should have a code…and you probably want to know what the code means, so check out these pages. Between these 4 pages you will DEFINANTLY find your code and what part of the car it refers to.
http://www.hondaswap.com/forums/inde...howtopic=29806
http://www.hondata.com/techecucodes.html
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 03-21-2005, 03:06 PM
$70./hr. Where do they charge that rate? They charge #115./hr in the SF Bay area.
Old 03-24-2005, 03:16 PM
blacknight's Avatar
blacknight blacknight is offline
Well, it depends upon what model you have. For the 6th gen Accords (98-02) you can Go to autozone and have them pull the code for you. They'll do it for free
Then go here to figure out what's wrong
Codes for check engine light
what's that red button on your steering wheel.......OOOHHH MMMYYY GODDDD :22yikes:
