Old 03-27-2002, 01:18 PM
mikeowen mikeowen is offline
cr-vtec or gsr
allright should i go cr-vtec in a 1995 civic hatch or gsr motor. I am definitely going to be adding forced induction so which would be better to do? the cr-vtec is a direct bolt in right? the prices are about the same but the cr-vtec is oblviously more complicated isn't it? what are the differences and which is better for a turbo?
thanks
Mike
Old 03-27-2002, 01:45 PM
90CRXZCSi's Avatar
90CRXZCSi 90CRXZCSi is offline
Send a message via AIM to 90CRXZCSi Send a message via Yahoo to 90CRXZCSi
Yes they will both bolt right in fine but the GSR(10.0:1) would be cheaper, easier to do, and better for turbo because it has a lower compression than the CRV(11.1:1) which is better for turbo. So i would say go with the GSR motor! Just Remember that lower compression is better for turbo.
2004 Sonic Blue Ford Ranger XLT
2001 Liquid Grey Metallic Ford Focus ZX3
1995 Integra GS-R - Parting out
Old 03-27-2002, 02:38 PM
Rice-Rocketeer Rice-Rocketeer is offline
Not only would the GSR motor be more expensive by atleast a grand but the B20 CR is not 11:1, the B20B had a CR of 9 something and a Z a bit a more.
Lookin at my gucci, it's about that time...
Old 03-27-2002, 10:44 PM
j.fuggi's Avatar
j.fuggi j.fuggi is offline
say i got a b18c1 swapped into my 5th gen. slapped on a drag gen 3 turbo. what boost would i have to run SAFELY on stock internals? i plan to upgrade so i can boost higher, but money = none now. 8-9 psi? and how would i regulate this boost. say if i wanted 10psi one minute... and 20psi the next?
» Supercharged 2006 Honda Civic Si Coupe
» Info | Teaser Video | Dyno Video | Dyno Graph
Old 03-28-2002, 08:47 AM
HXCivic97 HXCivic97 is offline
Send a message via AIM to HXCivic97
ok i'm not a turbo genious or anything, but i hear ppl talk about all this insane boost... 20psi? Is that for real? I mean, look at it this way - lets say your car's pushin 160 horses NA... well, normal atmospheric pressure at sealevel is 14.7, so with 20 psi boost, you're talking 34.7 psi, which is *pulling out the calculator* about a 136% power increase. Now, granted that turbos are not perfectly efficient, and therefor that's not a free power increase, lets knock it down to 125% power increase. Suddenly your 160 hp is now pushing with 360 horses ? I dunno, but i don't think stock internals on a civic can take that.... am i wrong? like I said I'm no expert, but I was under the impression that typical boost provided by a turbo was around 6-10 psi. Someone correct me if I'm wrong
Old 03-28-2002, 08:52 AM
90CRXZCSi's Avatar
ok im sorry...i guess i was thinkin of another motor...my bad...anyways....the CRV(B20B) has a CR of 8.8:1. So i guess that would overall be better than the GSR.
Old 03-28-2002, 03:01 PM
Yep 8-9. Any higher and you need forged internals and mad amounts of tuning. As for controling it, that what boost controllers are for.
No you're right, it's not possible on stock internals. 8 psi is the norm and If someone says he's pushing 20, he don't know jack shit of what he's talking about or he has alot of time and money to spend on his engine.
Kinda like a friend of mine last night telling me that his Mark 3 VW Golf with a stripped interior and $4000 worth of engine work can get him into the 9's.
Old 03-28-2002, 04:07 PM
jeisai jeisai is offline
Send a message via AIM to jeisai
How much would having a cr-vtec engine built cost? Some people seem to think it's really cheap, others make it sound like it's a 5-6g job. And does anyone know the reliability of a thing like that? I want something that would be safe for a daily driver.
Old 03-28-2002, 04:24 PM
Just like any other engine, depends on how far you want to go with it. Get a B20 block, with a B16 head and ECU and GSR tranny and it'll cost you less than FULLY building a high performance CRVTEC setup.
Old 03-28-2002, 04:43 PM
I'm guessing around 2g for a regular crvtec setup, more for a built turbo ready version?
Old 03-28-2002, 07:02 PM
HondaCivic405 HondaCivic405 is offline
Send a message via AIM to HondaCivic405
CRV or GSR
What i think is if your gonna get TURBO get the GSR motor becuz it has better COMP RATIO then the CRV due to after vtec swap you have HIGH COMP RATIO and i would know if you like TURBO .... GSR man ... ALL MOTOR is CRV/Vtec ..... i think in money wise they will be the same or CRV will be a little bit more so it what YOU like hahahah
HONDA-FREAK
:flash:
