Go Back   Automotive Forums Car Chat > Chevrolet > General Discussion
Old 03-17-2005, 02:06 AM
85S10358 85S10358 is offline
Send a message via AIM to 85S10358
2 bolt main question
I have an s10 with a small block and im currently rebuilding the engine, I found out that its a 2 bolt main block and i was concerned about the maximum amount of rpms that can turn with this, im building it pretty steep and the power range for it is going to be 2800-7000rpm, i was wondering what your suggestions would be, if the 2 bolt will be enough, or if i should consider a 4 bolt block, or a 4 bolt conversion, its a 355
Old 03-18-2005, 10:41 AM
chevystepside chevystepside is offline
Re: 2 bolt main question
I beleive that the 4 bolt will be better and safer for the project u are doing because the 2 will not be able to handle it as well
Old 03-28-2005, 03:25 AM
wicid_1 wicid_1 is offline
Send a message via MSN to wicid_1
a 2 bolt main block can easly handle 7000 rpms no problem (assumming it was built right ) but over the course of time a 4 bolt will definatley out last a 2 bolt. spend your money on the crank and rods they have to be good to do 7000 rpms and be reliable
