Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 03-17-2005, 12:11 AM
Vidneras Vidneras is offline
Unhappy 1986 Cutlass Cierra - stalling/dying problems
Hi all. First time poster here, hope you all can help.
I was driving on the freeway when all of the sudden it felt like it slipped out of gear. The engine revved like I was neutral. Then after about 2 seconds it seemed to have caught itself. It happened once more before I parked it.
After a real basic check under the hood, I took off again. I stopped at the light, and when it turned green I tried to take off but the engine died. I still had power but had to restart the car.
I asked around and some people suggested I might have a transmission problem, but my roomate suggested revving while it was in park to see if it sputters and dies. I did, and the engine died. He's suggesting that it might be a fuel line problem.
Does anyone here have any ideas based off of what's happened? I would appreciate any feedback you folks have. Thanks a ton!
Old 03-18-2005, 08:00 AM
dolluper dolluper is offline
Re: 1986 Cutlass Cierra - stalling/dying problems
As to the trannie check your fluid for colour brown =brunt change ,black=seals repair, red =good check level The tcc solenoid may be acting up or wire shorting[transmission convertor clutch] Stalling -check vac hoses leaking ,fuel filter, spark plugs or weak fuel pump ign wires
