Go Back   Automotive Forums Car Chat > Nissan > Altima
Old 03-16-2005, 11:59 PM
toast1985 toast1985 is offline
97 altima will not switch gears.
Hello, my 1997 Altima will not switch gears at a certain mph's, usually around the 40-60 mph range. I've taken it to transmission specialist, and they confirmed that it was not the tranny. I also took it to another motorist specialist, and they thought it was the vechicle speed sensor, but it wasn't.
...If anyone have any suggestions or have been in a similar situation, I really need your help....Thanks in advance.
Old 03-19-2005, 12:51 AM
TheQuietThings TheQuietThings is offline
Send a message via AIM to TheQuietThings
Re: 97 altima will not switch gears.
im not really sure what youre trying to find out, is the car not upshifting or downshifting when at those rpms? if you slam the gas at 40mph in the altima, itll put you in 2nd gear around 3krpm, and it wont downshift from there. i'm not sure if i answered your question, and im pretty sure it didnt, but if you can specify upshifting or downshifting that would help me help you lol
Old 03-20-2005, 01:04 PM
wonword wonword is offline
Send a message via AIM to wonword
Could be a problem with linkage.
94' Nissan Altima SE
K&N High Flow Air Filter
Greddy St Exhaust
OBX Header
Short Throw Shifter
Extreme Performance Clutch
68' AMC Abassador
Chevy 350
TH 350 Tranny
Headers
Dual Exhaust
1999 Suzuki GSX-R 600
Yellow/Black
Yoshimura Exhaust
http://members.cardomain.com/wonword
Old 05-07-2005, 02:25 AM
JustSayGo JustSayGo is offline
Send a message via AIM to JustSayGo Send a message via Skype™ to JustSayGo
Re: Re: 97 altima will not switch gears.
There is a part in the dash called a Reed switch that translates the signal from the speed sensor and sends a signal to the transmission computer telling it how fast the car is going. The transmission computer won't show a code because it has no way to know how fast the car is going and compare it to the signal. Maybe it is diagnosed by using a scanner and comparing the signal to the speedometer.
