Go Back   Automotive Forums Car Chat > Ford > Probe
Old 03-16-2005, 11:58 PM
vonage003 vonage003 is offline
Unhappy Oil Problem !!!
Alright, i have a 1994 ford probe Gt and i am burning alot alot alot of gas for one! second, on top of all the money i throw into that, my car is burning oil...yes there are obvious things i can check for the oil leak but let me ask.....has anyone ever heard of pulling the oil dip-stick out of the tube while the car is running, and it makes the car choke (almost stall) i put my finger over the dip-stick hole and it is sucking about 5psi of air through it....WHAAAAT the he*ll is up with that and has anyone ever hear of such a thing? PLEASE! your information will definatly make me sleep better at night...because i love this car and its going to have to last! THANKS!!
Old 03-18-2005, 11:44 AM
93 probe 93 probe is offline
Send a message via AIM to 93 probe
i have heard of it dying out when u pull the dip stick or take the oil cap off cause my GT does it 2, but my SE doesnt do it. So i need help with the same thing
Old 03-24-2005, 01:01 PM
stompsfrogs stompsfrogs is offline
Send a message via AIM to stompsfrogs
Re: Oil Problem !!!
just a guess, sounds like a wicked draft. check your muffler?
Old 03-25-2005, 06:11 PM
Re: Re: Oil Problem !!!
Hey thanks for replying! Most cars rmp's fall when you take the oil dip-stick out while running...nothing to worry about! i only have one more problems im burning alot of gas ( brunging very rich) can you or anyone who happens to catch this thread help me out on why i have like 6 MPG!? "HELPFUL" info much appreciated thanks!
Old 03-26-2005, 06:19 PM
backinblack backinblack is offline
More than likely your Oxygen sensor is out. This will definately cause the car to run rich and burn alot of fuel. As far as the vacuum in the the crankcase, I would check your PVC valve. It is meant to vent the vacuum in the crankcase and also rid the car of unburned gases by redirecting them back into the combustion chamber. If it is not functioning, it will cause a vacuum surge in the oil pan, thereby causing the symtoms you are describing.
Who says that snow sux? It is the only way I can burn out!!
95 PGT ATX. Weapon R intake, fart can, coilovers
Old 04-04-2005, 05:35 PM
shawnwilliams's Avatar
shawnwilliams shawnwilliams is offline
Re: Oil Problem !!!
Check out your head gasket for the oil. About the dipstick i believe its the high compression of the v6. When u remove the dip the pressure escapes quick and the engines rms will usually move up and down.
93 FORD PROBE GT
JDM manifold ported match
65mm TB
Unorthodox Underdrive Pulley
Hotshot headers
3' Exhaust all the way
No cat
Cold air intake
K&N air filter
Short throw shifter
Eibach lowering springs
FX Design Body Kit
B&M Short Shifter
Stage 3 Clutch
MX-3 Flywheel
Performace Wires and Plugs
Synthetics
Performance Rad and fan
Mild Weight Reduction
Coming this week:
Performance Heads and Cams
3 angle head job
Why does everyone have to piss on Ford.
Old 04-05-2005, 11:09 PM
your enrichment valve could be stuck open, that would make you suck gas. just another guess.
Old 04-14-2005, 02:04 PM
Re: Oil Problem !!!
or maybe you have a hole in your tank. Might want to check it out.
93 FORD PROBE GT
65mm TB
Hotshot headers
No cat
Cold air intake
K&N air filter
Short throw shifter
FX Design Body Kit
B&M Short Shifter
Stage 3 Clutch
MX-3 Flywheel
Synthetics
Coming this week:
3 angle head job
