Go Back   Automotive Forums Car Chat > Honda > Del Sol
Old 03-16-2005, 10:08 PM
speedster_74 speedster_74 is offline
93 del sol window seal problem!!
i have a 93 del sol and i had to replace the driver side window and now it leaks when i wash it and when it rains hard and so does my pasenger side any help on that would be great thanx.
Old 03-17-2005, 10:57 AM
Plastic_Fork's Avatar
Plastic_Fork Plastic_Fork is offline
Re: 93 del sol window seal problem!!
Where's the water coming in when it leaks? The roof seals for '93-'94 Del Sol's had a recall because they leaked. The seal design was changed in '95+ Del Sol's.
1995 Honda CRX del Sol VTEC
Manufactured: Suzuka, Japan
Production Sequence #1269
Team Del Sol member #1131
HondaVision: Team Sol Forum - Home of Team Del Sol
Old 03-18-2005, 05:05 PM
it leaks at the point of the triangle window in the front
Old 03-18-2005, 10:28 PM
Yep, that's the roof seal leak that the early Sol's where known for. The answer to your issue is new roof seals from Honda. It'll run you about $500 - $700 (I believe) for the parts and installation. Honda dealer is really the only place you're going to find the roof seals.
In the mean time, try lubing the seals and see if that helps. A good lube on the seals is good for regular maintenance anyway and is a good idea to do every now and again (I do mine about once a month). Go here to get the part number for the silicone grease and how to keep the seals maintaned:
http://www.teamdelsol.com/technical/...ce/default.asp
I would also recommend the silicone spray that Honda sells. Use it on the rubber seal areas that touch the windows. When it dries, it'll have a good seal but won't smear.
