Old 03-16-2005, 09:57 PM
kelrx8-civicbeater kelrx8-civicbeater is offline
Send a message via AIM to kelrx8-civicbeater
oil in spark plugs, o-ring ?- need some help on my 91 civix dx
hello guys
i have a question
i went to replace my spark plugs and noticed 3 of them were sitting in oil
im looking at getting some o-rings from the dealer tommorow but have no idea how much work im looking at. is it fairly a simple task
any help please
also its not the spark plug tube seal since its from the bottom where the plugs are.
thanks
Old 03-16-2005, 11:12 PM
Hilikus Funkin's Avatar
Hilikus Funkin Hilikus Funkin is offline
Send a message via AIM to Hilikus Funkin
Re: oil in spark plugs, o-ring ?- need some help on my 91 civix dx
you sure it not from the valve cover gasket? I just replaced my valve cover gasket and all the gromets and the little rings that go around the spark plug stems fell apart when i took em off and thats why i had oil in 3 of mine. I got a couple pics of the valve cover and the head acctually, just gotta email em from my phone.
1991 Honda Civic DX Sedan
Old 03-16-2005, 11:16 PM
Re: Re: oil in spark plugs, o-ring ?- need some help on my 91 civix dx
thankyou for reply
please email them too me
[email protected]
Old 03-16-2005, 11:27 PM
BullShifter's Avatar
Re: Re: Re: oil in spark plugs, o-ring ?- need some help on my 91 civix dx
It's pretty simple to replace the seals. You should also replace the valve cover gasket since the valve cover needs to be removed.
Remove the valve cover nuts
Pry out old seals
Install new ones, use a little oil on them if they fight you going in
Lay new valve cover gasket in the valve cover AND MAKE SURE to put a dab of liquid gasket at the 4 corners at the cam cut outs. They are usually square on the gasket.
If it still leaks there are another set of seals down in the head, the spark plug tubes are halves with the seal in the middle. This a bit more complicated since the rocker assy. needs to be removed followed by a valve adjustment.
Nothing like spending $60.00 on a factory manual www.helminc.com that has every thing you need to know unlike a Shitlons or Haynes toliet paper book.
Old 03-16-2005, 11:46 PM
why email em when i can post em?
Old 03-17-2005, 07:22 PM
Civix's Avatar
Civix Civix is offline
Hey, do you always replace those seals evertime you take off the valve cover or is it alright to put the cover back on with the original seals?
With my Civic, I'm Pimping Yo
Old 03-17-2005, 10:07 PM
my local napa dealer is a idiot, they ordered teh wrong part.
they sell just the spark plug tubes and valve gasket
spark plug tubes are $3.50
and gasket is $10.00
'91 CIVIC
'91 CIVIC SEDAN
'90 CRX SI -sold
'90 INTEGRA COUPE
'04 MAZDA RX8
Maido ST5 20x9 & 20x10
toyo proxes
Old 03-17-2005, 10:33 PM
No you don't have to replace them every time, but if they are old it's wise to replace them. That way you only need to take it apart once.
Old 03-18-2005, 10:11 AM
4thgenracer 4thgenracer is offline
try the head gasket
Old 03-18-2005, 11:47 AM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
Originally Posted by 4thgenracer
try the head gasket
No
ZC stuff
http://dh-racing.com
http://www.thezcr.com/html/zcbook.php
http://dmoore.com/crx/zc.htm
http://www.jgenginedynamics.com/HOME%20PAGE
http://www.theoldone.com/
