Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 03-16-2005, 09:55 PM
blastingcoffee blastingcoffee is offline
Send a message via Yahoo to blastingcoffee
transmission
hey y'all,,,,i'm a newby at this so please gimme some slack...
i have an 89 suburban,,,how do i find out what kinf of tranny is in it?,,,,thanks!!!
Old 03-16-2005, 11:54 PM
amac209 amac209 is offline
Send a message via MSN to amac209
Re: transmission
i think all the 89's are 700R-4 if you have PRNODD21 and a kickdown cable on the throttle linkage it's a 700R-4 for sure.
Old 03-17-2005, 02:44 PM
pgutierrez pgutierrez is offline
I have an '89 2500 3/4 ton 2wd with a TH400 (turbo hydromatic). Look at the tranny and if you have a connector on the right side that connects to a rubber hose....you have the TH400
Paul
Old 03-17-2005, 06:33 PM
IA-Suburban IA-Suburban is offline
Re: transmission
is the 700r4 an overdrive and the th400 just a 3 speed? Anyone confirm?
Old 03-17-2005, 06:45 PM
2000CAYukon 2000CAYukon is offline
Re: Re: transmission
That is correct.
//2000CAYukon
Old 03-17-2005, 08:16 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: transmission
That may be on suburbans, but my 700r4 is a 3 speed, At least according to the RPO code in the glove box. Mine is also (according to the original owner) the first year they had the O/D option ('86)
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 03-17-2005, 09:09 PM
Re: transmission
all 700R-4's are 4 speed. if you have a 3 speed it's probably a TH-350
Old 03-18-2005, 11:51 AM
Re: transmission
You are most likely going to want the cataloge from lmc if you are a new suburban owner. In the catalog there is a diagram showing how to identify your tranny by the shape of the pan. The most square is the 700r I believe
http://www.lmctruck.com/
