Hi, I have no spark, and no power to the coil from the computer. I checked the coil and it shows zero volts at the positive side of the coil. I then used a jumper wire to the battery and still no start or spark to the coil secondary. I assume this means that there is also no trigger being made by the distributor, or computer. I'm wondering what would cause no Pos. or Neg. to the coil? Seems like a computer, but I get code 55 which indicates no computer issues. I'm baffled, as I could see the distributor going out causing the Neg side to not pulse, but the Pos is not getting power either, so I'm guessing computer. Anyone know of any other tests to try, before i replace a computer?
Thanks much, Jim |
Re: No Spark 88 New Yorker 3.0
Aw, Come on people. Someone must've gone through a similar issue on these darn ignition systems. I really could use some advice if anyone has even a posibility.....................PLEASE?
Jim |
r u geting power to comp at all? IF u r before u change comp check loom from comp to coil might be break or something not sure if this helps or if u still have a problem cos its been a while. if its not fixed hope this does help.
Re: Re: No Spark 88 New Yorker 3.0
Thanks again |
