Old 03-16-2005, 08:38 PM
irupp33's Avatar
irupp33 irupp33 is offline
Send a message via AIM to irupp33
Do these actually work?
J/w if these actually work. How are they installed? N E one know?
http://cgi.ebay.com/ebaymotors/ws/eB...sPageName=WDVW
Old 03-16-2005, 09:09 PM
96spyderman's Avatar
96spyderman 96spyderman is offline
Send a message via AIM to 96spyderman Send a message via MSN to 96spyderman
Re: Do these actually work?
Yes they do work... but I beleive they also need to have a MAF translator if you vent to the atmosphere....
"A man's greatest work is to break his enemies, to drive them before him, to take from them all the things that have been theirs." -Ghengis Khan
Old 03-16-2005, 09:18 PM
shadow eclipse shadow eclipse is offline
Send a message via AIM to shadow eclipse
The inlet on the bov is the same diameter as the stock bov, which allows it to simply slide into the stock intercooler piping and clamp down. Very easy, very quick installation, but as spyderman stated, you cant use with stock mass if you want the car to run right
95 GSX 14.748
90 GSX
Old 03-16-2005, 09:39 PM
tsi4444 tsi4444 is offline
Do you know of any vendors that sell Maf translators?
97 TSI AWD
Apexi N1
RRE Downpipe w/test pipe, K&N FIPK, RRE lightened flywheel, ACT 2600, New short block installed due to crankwalk,autometer sport comp boost gauge,type-s bov, brode uicp, Johnny race car fmic with custom piping, evo 3 16g
Soon to be purchased: DSM link, injectors, fuel pump
Old 03-16-2005, 10:51 PM
Ebay, slow boy racing, dsmtuners.com, ect. They aren't hard to find, you need a gm 3 inch mass(about 45-50 bucks used on ebay) and a maf translator (aleast 200 bucks on ebay or other vendor) this will allow you to vent to the atmosphere without hurting performence
95 GSX 14.748
90 GSX
Old 03-16-2005, 11:19 PM
Shpyder's Avatar
Shpyder Shpyder is offline
Moderate moderator
i wonder if that thing really can hold upto 30 psi, like stated....also wonder what it sounds like.
The daily driver. The weekend cruiser. The lazy shop hog.
Old 03-16-2005, 11:54 PM
97_3clipse's Avatar
97_3clipse 97_3clipse is offline
Send a message via AIM to 97_3clipse
thoes cross drilled timming belts are the bomb B! haha i love ebay
1998 Eagle Talon TSi AWD
6 Bolt Swap \ DSMLink V2.5 \ ACT 2100 clutch \ PTE SCM 61 \ Forge MBC@28psi \ VPE O2 Housing \ MR Downpipe \ Thermal R&D Cat-Back \ Tial 38mm WG dumping off O2 \ FMIC w\ in short route \ AFPR setup/walbro 255hp \ PTE 880cc injectors \ Crower Ti retianers \ Crower Springs \ Crower 64414 (stage 3 race) cams \ Ferrea valves \ 3.5 bar MAP \ PLX M-300 Wideband
Old 03-17-2005, 08:11 AM
Re: Re: Do these actually work?
I think that it should hold 30 psi becase of its piston design, but kevin said he had problems with his rfl bov because the o rings leaked. Im not sure if this one has them but if it does they might become a problem This guy I know had a gst with a turbo xs bov with holes in it just like this one, I imagine this one sounds quite similar, like a big whoosh of air, also like the rfl but maybe not as loud because of the horn.I would much rather have my greddy type-s
95 GSX 14.748
90 GSX
