Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 03-16-2005, 08:09 PM
billyrohm billyrohm is offline
1991 Burban back up lights
Back up lights just stopped working, both at the same time, all fuses good. Where is the sensor that tells the lights to come on?
Old 03-16-2005, 11:23 PM
amac209 amac209 is offline
Send a message via MSN to amac209
Re: 1991 Burban back up lights
a switch at the transmission
Old 03-17-2005, 05:37 AM
Re: Re: 1991 Burban back up lights
As in in the Transmission, on the transmission, left side, right side, top?
Old 03-17-2005, 08:30 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Do they come on with the gear selector toward park or neutral? Mine did that a while back, now they've stopped working all together. If it does that, it's almost certainly the switch.
The switch is by the shift linkage.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 03-17-2005, 09:54 PM
Dont come on at all, where is the switch exactly??
