Go Back   Automotive Forums Car Chat > Pontiac > Vibe > General Discussion
Old 03-16-2005, 08:08 PM
jvmrn jvmrn is offline
Send a message via MSN to jvmrn
Help Please!!!!
hey i have a 2003 vibe ........i was spraying my engine with my power washer and when i was done i was driving down the street and i lost all power to my dash no lights speedo would not work nothing at all. it went out for about 20 seconds then it all came back on......this happened a few times ......now there is no power to the dash at all..the car however runs perfect........any ideas please help
Old 03-17-2005, 05:20 AM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: Help Please!!!!
Check the connections to the body control module. (BCM) It sounds like you got water in them and they are not making contact. It is usually located close to the firewall but I am not exactly sure where on the Vibe. Remove the connectors and spray them with compressed air or contact cleaner and reinsert them. This should take care of your problems. You may also want to check to see if you got water in the power control center where all the relays are, this could also cause similar problems, you can cure them in a similar fashion.
