| F-Body Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible. |
| View Poll Results: Doesn't it want to make you throw up? | |||
| dry heive? |
2 | 50.00% |
| gag? |
0 | 0% |
| Throw up? |
0 | 0% |
| Uncontrolable vomitting? |
2 | 50.00% |
| Multiple Choice Poll. Voters: 4. You may not vote on this poll | |||
just out to say that this past weekend I had just finished building my brand new Pontiac 400 6.6L engine. We where at the dyno and almost finished doing the run, running it up for the last reading she talked to us at 550Hp and 575 ft. lbs. of torque, when she blew the head gasket and hydrolocked the number 7 cylinder. At 4000 rpm she came to a dead stop for a split second then sheared the block, crank, cam and all right between numbers 7 & 5 cylinders.
![]() ![]() laid to rest I will start on number two! CAn anybody help to understand why the head gasket blew, especially after great care and effort was put forth. I have never had this problem on a small block chevy and not to familiar with the pontiac 400 but I know that it should not have done that. |
Re: 550 H.P. HydroLock
the engine had a billet crank and mr. gasket copper head gaskets I know about o-ringing the block but that is mainly for boosted engines. the rods were eagle h-beam rods with hyperuetectic pistons from summit. I was sure that it would go at least up to 6500-7000 rpm with ease. and yes we took it up to 6500 several times but didn't reach it before it blew. I actually went in five increments when i torqued the heads, as a practice i have done for years.
Re: Re: 550 H.P. HydroLock
i'd say the 6500 rpm's had something to do with it,, makes me wonder if you didn't spin a bearing before everything else happened, you can read in numerous engine building books and such that 6500 rpm is not good for a pontiac engine, does your block have 2 bolt or 4 bolt mains? also valve float starts at around 5500 rpm depending on the lift,and to reach that power level i'm sure you had a nice aggressive cam in there also... |
How much did this engine cost to build and produce that much horsepower? I would love to throw something like that into my 79 Bird. If you could let me know the year of the block and a few of the key engine components you used, it could be of great help to me.
Hello, you could check Car Craft, High Performance Pontiac issues, within the last year they had some buildups of those type of engines, I'm in the stages of building my 400, don't mind sharing the components and prices I expect to be in the same power range(if not,I don't care but I'm sure it will make enough power for my car..), here is the breakdown: 1978 400 block $30 1970 #13 heads $200 prepping them another $100 Manley Stainless valves, black melonite $175 Rest of the valvetrain (camshaft,pushrods,springs,retainers,lifters):$110 0 specs of the cam: hydraulic roller competition cams, cam with hydraulic rollers, duration 288/294 lift 520/540. Harland sharp aluminum roller rockers $200 7 " aluminum BME connecting rods (price new $1500) bought used for $350 set of 8 pistons BME out of DEI Nascar engine (price new $1200), bought used for $100 High volume oil pump $40 Bearings $110 Head gaskets $100 Oil Rings $180 Warrior intake bought used for $300, polishing another $100 Pete Jackson gear drive (new for $250) bought used for $80 Timing chain cover new paid 100 and change, plus $100 to polish Holley double pumper carb slightly used $120 Crane ignition (not sure but believe I paid $200) On that you have to add the gaskets, oilpan and distributor Stock crank 10/10 under $154. Maybe this info helped you. |
to start out I bought a
Crower Billet Steel crankshaft: $2500 Eagle H-Beam Raods With standard Measurments: $569.00 KRE billet four bolt splayed main caps: $265.00 JE SRP pistons:$505.00 KRE lifter bore brace:$190.00 Crane Cams Energizer Cam With 242/242* and .484"lift cam: $140.00 That should get you started on a good strong engine. Oh yeah it has been checked out by several people and they have told me that the billet main caps had a small air bubble in one and forced it to go, so they are sending me a new set free of charge. I have also been told that the engine was quite solid and capable of well above 9000 rpm if it was not for the air bubble. they vavles will not start floating at 5500 rpm unless it is a stock motor racing engines won't start until 8500 - 9000 rpm's and then the cams are designed to make them float to get the maximum lift. this was just a freak incident and in a few months it will be ready again. I guess I will just have to sit track side this week end and watch. This time alot more will change including the engine will now be a 638 c.i. aluminum pontiac and mean to boot |
By the way what every you do do not use a stock crank. You will rip it apart before it would ever get started. Yes they are cheaper but it is worth the money for a billet crank
a 638 ci? crazy.. how much horse you expecting to push...?
P.s if you a a video or sound clip of it i wouldnt mind hearin it |
no at this time i do not have any audio or video but i am still working on that. I was told that some geologists that were also avid drag racing fans put one of these engines 50 feet away from a sizemometer and it registered 3.27 at idle and 6.78 at launch on the richter scale. That that's cool!
haha that sounds awsome.. if you get an audio or vid lemme know
will do
thanks
Old thread... Poll closed, thread locked...
-Brian
