Go Back   Automotive Forums Car Chat > GMC > Jimmy
Old 03-16-2005, 07:26 PM
rstyrlz rstyrlz is offline
MAP Sensor
Bought an '87 S15 Jimmy with the 2.8L v6 (approx. 174,000 miles)it has a low idle speed and a rough idle I can't get to go away. Codes said MAP sensor ,changed that, still got the code, decided to do a tune up i.e. plugs,wires,cap,rotor, still got MAP sensor code, tried to adjust TPS no change in idle speed, changed the O2 sensor and still no change. While changing plug wires I noticed the distributor was loose so I grabbed my timing light and set the timing the best I could, now when I run the codes I get a TPS code , a MAP sensor code , And An O2 sensor rich code. Could this be a vacuum leak , EGR , or timing problem? or maybe all three?
Old 03-16-2005, 08:37 PM
dramey_2004 dramey_2004 is offline
rough idle jimmy
It sounds like an egr problem. try taking it off and cleaning the carbon deposits out of it. Take air filter grabv a spray bottle of water and shot in the intake through the throtle body slowly take your time this will clean any carbon deposits out of the engine do this before you take your egr off. Trust me on this it my sound shady but trust me it will work just take your time. Also when your engine is running look down at your 2 injector spray patters.
Old 03-16-2005, 09:33 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: MAP Sensor
Did you set the timing with the timing wire unhooked from the PCM?
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 03-17-2005, 01:07 PM
distributor
Your pcm will retaurd and advance your timing all you need to do is put it in and lock it down right where it was before or just keep it in the center. You do not adjust timing on this vechicle
Old 03-17-2005, 01:12 PM
BlazerLT's Avatar
AF -Advisor
Re: distributor
Please know what your talking about before you post answers like that.
You are wrong, he just can't throw it in there and have the computer auto adjust it!
He does have to set his base timing on that truck. All trucks that are OBDI have base timing that needs to be set properly with the timing wire unattached from the PCM.
Old 03-17-2005, 01:56 PM
I did not unhook timimg wire- I think I'll let a pro set the timing and then start from there. thanx for all the help
Old 03-17-2005, 04:15 PM
BlazerLT's Avatar
AF -Advisor
Re: MAP Sensor
Old 03-17-2005, 06:03 PM
blazes9395's Avatar
blazes9395 blazes9395 is offline
Newbie mod
Your more than half way there setting the timing....just disconnect the timing wire, LT gave you the picture, its the only thing there to unplug. Unplug it and start it, the Service Engine light will come don't worry, adjust your timing to the degrees specified on the VECI label under the hood, I think its 0 degrees if im not mistaken. Reconnect the timing wire, reset the computer by unplugging the fueses or the easiest unplugging the battery and your done. As for the MAP, make sure it is getting vaccuum from the manifold and that the vaccuum l;ine is not plugged. Get a vaccuum tester and make sure it is a good source of vaccuum. If it isn't it will not be sensing anything for the computer, setting the code.
Old 03-20-2005, 05:46 PM
Thanx for the pic and all the help. I'll give it another go.
Old 03-21-2005, 10:51 PM
96jimmy4wd 96jimmy4wd is offline
Re: MAP Sensor
if you are getting good vaccuum (14 in hg with accumulator unplugged) check signal voltage there should be 3 wires ground, 5v ref, and signal, should be 4.5v with ign off and wot and about .5v at idle volts should rise as vaccuum falls (as you give it throttle)
Old 03-24-2005, 06:57 PM
The sticker under the hood was unreadable but a website told me what the timing is (10 degs.) I reset timing(this time with timing wire unhooked) Still no change but I unhooked vac line to EGR and now it idles smooth . As soon as I can I'll replace the EGR and it's gasket. this may be a dumb question but the manual I have doesn't tell me . Anyone know what the idle speed should be ?
Old 03-24-2005, 08:30 PM
BlazerLT's Avatar
AF -Advisor
Re: MAP Sensor
The timing should be set to ZERO with the timing wire off.
