Go Back   Automotive Forums Car Chat > Honda > Wheels/Tires/Suspension
Wheels/Tires/Suspension All the handling help you need. No matter what Honda/Acura you drive.
Old 03-16-2005, 07:35 PM
km23honda's Avatar
km23honda km23honda is offline
Send a message via AIM to km23honda Send a message via MSN to km23honda Send a message via Yahoo to km23honda
Sway Bar
Do i need one?
A friend of mine drove my car one day and said that my streeing wheel had a lot of movment in it. Example it wiggles apon braking and at higher speeds (50 to about 70). This is when i notice the wiggling the most. And from this same friend told me to get a sway bar.
From my knowledge and what i have read that sway bars are for the body roll and better handling. IN my case would it get rid of the wiggling in the streeing wheel?
My car is a 92 prelude, i did lower it with Coil overs and had it alined by les schwab. Other then that nothing else was done to the suspension. Oh yeah i have front strut bar. 205/16/45Z Tires
1992 Honda Prelude SI
Old 03-16-2005, 08:02 PM
240SXLude 240SXLude is offline
Re: Sway Bar
Originally Posted by km23honda
Do i need one?
Usually, correct me if i'm wrong when ur steering wheel shakes when braking its your rotors. Also check ur tires u may need new ones along with getting ur wheels balanced.
Old 03-16-2005, 08:39 PM
SilverY2KCivic's Avatar
SilverY2KCivic SilverY2KCivic is offline
Cali Guy
Send a message via ICQ to SilverY2KCivic Send a message via AIM to SilverY2KCivic Send a message via Yahoo to SilverY2KCivic
Re: Re: Sway Bar
Agreed, swaybars are only for handling and turning, NOT for straight line. Check your rotors first for warping, then check your tires to see how they are wearing (perhaps unevenly) and if those check out ok, then a set of strut tower bars might help you out.
Silver '00 Civic EJ6 Coupe
PureHonda original member since Feb. 2000
D-series revolution For pics of my baby, click here!
All rights reserved... All BITERS served!
"The last time you had THIS much fun driving a car, it cost a quarter, and gyrated in front of the supermarket."
i have yet to see any well done imports around here. most are road toilets driven by some high school punk -Drift
hessemer69 on AIM
Old 04-04-2005, 07:02 PM
km23honda's Avatar
UPDATE!!!!
Went to Les schwab and got rotors check out, truns out that it was the rotors and is fixed now. I drive it to check out the rotors there is no play or movment in the streeing wheel when braking. But going about 50mph i find that there is a slight movement very small not enough to bother me. I just wanted to know if this could be normally (nothing to worry about) or if anyone can think of something what could cause this problem. Thanks for the HELP
Old 04-04-2005, 07:33 PM
BullShifter's Avatar
Re: Sway Bar
50mph doing what? Cruising, Braking, Accelerating?
If it's cruising, wheel balance is the place to start.
Old 04-04-2005, 07:54 PM
BrodyP's Avatar
BrodyP BrodyP is offline
AF -Advisor
Re: Sway Bar
^^ Hey Jackassi what if it were shaking when braking only?
03.IS300.MT.LSD. 'Supra in Training'
Old 04-04-2005, 09:37 PM
CivicSiRacer's Avatar
CivicSiRacer CivicSiRacer is offline
Civic Mod
Send a message via ICQ to CivicSiRacer Send a message via AIM to CivicSiRacer
Re: Re: Sway Bar
then it's rotor warpage
Sponsored by: KAM Racing Sports, Falken Tires, Finish First Polish, Brady's High Performance, Taggart Performance Engineering, Rotora Brakes
Autocross is: 90% driver, 5% car, & 5% CRAZY MOJO!
Autocross Help Page
Buy my Civic parts!
Old 04-05-2005, 12:03 PM
BrodyP's Avatar
AF -Advisor
Re: Re: Re: Sway Bar
Thanks man..my car is only 15 months old tho....weird
Old 04-05-2005, 04:43 PM
Re: Re: Re: Re: Sway Bar
you must ride the brakes a lot to have warped rotor's on a 15 month old car. have you done any brake services? if a pad is slightly stuck it could cause a warped rotor.
MAINTENANCE! yes it's a honda and they still need maintenance.
Old 04-05-2005, 05:09 PM
BrodyP's Avatar
AF -Advisor
Re: Re: Re: Re: Re: Sway Bar
LOL funny yes I know about maintenance..I have not had the brakes done I have 25k on the car right now. I dont use the brakes at all like I did in my automatic car..I tend to downshift most of the time. I have noticed that my wheels are not alligned I tend to sway to the right. I figured that might be causing it. I'll take em all off this weekend and inspect..Thanks for your help.
Old 04-07-2005, 09:35 PM
projectsilvia97's Avatar
projectsilvia97 projectsilvia97 is offline
Send a message via AIM to projectsilvia97
Re: Re: Sway Bar
^werd^
Stock 1992 Civic DX hatch
