Go Back   Automotive Forums Car Chat > GMC > Sonoma | S-15
Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 03-16-2005, 05:17 PM
vweaber vweaber is offline
1999 Sonoma Wiper Problem
I have a 99 Sonoma and the wipers only work on high speed. When turned to intermittent or slow(no work at all). Is there a pulse module for the wiper motor, and if so, Where is it located?
Old 03-16-2005, 07:51 PM
SpitAndDirt's Avatar
SpitAndDirt SpitAndDirt is offline
Re: 1999 Sonoma Wiper Problem
If it's anything like the full size pickups, the pulse module is located in the wiper motor assembly. You can access it by removing three torx head screws(T15 or T20) and wiggling the board out. Oreillys now sells the pulse board in their Help/Motormite section for about $30.
Old 03-22-2005, 06:21 PM
Thanks much SpitandDirt. Pulled the module and found a broken ground connection that was easily soldered. Thanks again for the info.
Old 09-27-2005, 02:41 PM
jack720 jack720 is offline
how I fixed my wiper problem
97 Sonoma, 4.3L -- I had an intermittent wiper problem for a long time -- it seemed like every time I needed my wipers, ie. it's raining, they'd quit on me -- a few weeks ago I removed 3 torx screws from the wiper motor housing exposing the back of the circuit board -- then I wrestled the board out of the motor housing and removed the wiring harness -- then I resoldered the harness pins to the connections on the board with some more solder and a solder pistol -- reconnected the harness to the board, inserted it back into the housing, and replaced the cover. So far, no failures when I need the wipers -- I hope this helps - jack
Old 05-05-2007, 02:15 PM
Mad Jack Cash Mad Jack Cash is offline
Re: how I fixed my wiper problem
97 Sonoma 4.3L 4X4
Nothing is scarier (or deadlier)on the freeway than having a sudden downpour and switching from intermediate to constast wipers they stop working! Mine did it and I've read more than a handful of similar posts on other sites that suggested a grounding problem in the motor.
Try this fix first!
Simply make up a jumper wire with (strong) alligator clips and connect one end of it to the wiper motor housing and the other to a good ground point on the body/frame.
I'm no master mechanic but I Am an electronics tech and I read about the symptom enough that it showed me to be a floating ground between the circuit board and ground. I did this 4 months ago and it solved the problam instantly.
And belive me, living in Oregon it's had pleeeeenty of testing in the last few months!!!
Total cost - Zero, zip, nada. I had the jumper my toolbag.
Peace
Old 05-15-2007, 10:15 PM
ZL1power69's Avatar
ZL1power69 ZL1power69 is offline
GM S-Series Mod
welcome to af. this thread is now over 2 years old. please refrain from posting in old threads.
2000 Chevy Blazer ZR2
Performance Mods: Numerous
Suspension Mods: Some, but not enough
Exterior Mods: Just Right
1987 Buick Turbo T Dark Red
Low 11 sec sleeper
.030 4.1 block, PT6262E, & other odds and ends....
My Cardomain
Closed Thread
