Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon
Old 03-16-2005, 05:13 PM
pull pull is offline
Unhappy oil light
ok guys needs some help, about week ago my neon gave me a check oil light so i did and it only needed half a quart,week later light came on again but the oil is fine, the car has a real small oil leak ,could it be something else,, thanks for any help
Old 03-07-2006, 11:06 AM
Ekffazr Ekffazr is offline
Cool Re: oil light
has this been addressed? I have the identical problem
Old 03-07-2006, 01:18 PM
das2123 das2123 is offline
Tuning Neons since '97
Send a message via AIM to das2123 Send a message via Yahoo to das2123
Re: oil light
Oil sending unit may be going out. The oil "idiot" light measures pressure drop which is a result of low oil. If you are getting the light, make sure your oil level is good.
Old 03-07-2006, 01:56 PM
Re: oil light
first thanx for the response!!!!!!
ok, checked the oil first thing after light came on........right where it should be
just changed it 2 weeks ago as well......
so this can still be a symptom of sending unit then????
thank you for your assistance
Old 03-07-2006, 02:39 PM
Re: oil light
Yep, could be a problem with the pressure switch/connection. If not that, then you may have oil aeration which could cause the light to flicker.
Old 03-07-2006, 08:25 PM
nuwt's Avatar
nuwt nuwt is offline
Send a message via ICQ to nuwt
Re: oil light
My wifes oil light is on and I have tried several different things. Drive it till it breaks then buy a good one. Sorry to be mean or rude, but thats my thinking now.
oh!!
lucas may help also, use it on oil changes and if it is oil pressure problem then there may be a difference. if not then an electrical problem.
Laugh all you want!!!! I have NO Payments!!!
Old 03-08-2006, 10:54 AM
Question Re: oil light
ok, lets say that areation is the problem.........can I assume that an oil change will solve this?
last time the oil got changed (at a fast lube place) they put in "high mileage" oil. has anyone heard of this causing the problem?
I dont try to be dumb, it just happens naturally
again Thank you
Old 03-08-2006, 11:03 AM
Re: oil light
Yes, if aeration is the problem.
