Old 03-16-2005, 04:28 PM
escort_gt2000's Avatar
escort_gt2000 escort_gt2000 is offline
Talon 5speed swap
My friend and i just completed a 5 speed swap in his automatic 91 talon tsi. anything that could go wrong went wrong but it worked well. it took us a week because of all the problems we were having. if you have any questions about what you need or anything else for this swap post or email me at [email protected]
Old 03-16-2005, 04:41 PM
macder macder is offline
Send a message via MSN to macder
Re: Talon 5speed swap
This is the 3rd auto to manual swap thread in 2 days.
http://www.automotiveforums.com/vbul...d.php?t=381118
http://www.automotiveforums.com/vbul...d.php?t=378637
All on the main page. Damn
1993 Eagle Talon ES (4g63NA)
14.6 @ 98 mph (110 octane race fuel)
-5 Speed Transmission (From a 4g67)
-Stage 2 Crane cams
-Ported and polished head
-Aggresive valve springs
-2.5" Custom made exhaust piping
-Custom header
-Gutted catalytic converter
-Bored 0.5mm
-Advanced ignition timing (CAS) aprox. 5 degrees (set @ ~10deg BTDC)
-2g valve lifters (Lifter noise returned, now it a true DSM)
-K&N w/modified air canister
Old 03-16-2005, 04:58 PM
shadow eclipse shadow eclipse is offline
Send a message via AIM to shadow eclipse
I think Hes trying to stop these posts actually because he is not asking any questions, he has offered to answer their questions for us. Which I think is a great idea maybe they will just email him instead of posting the same damn subject. I hope it works!!
95 GSX 14.748
90 GSX
Old 03-16-2005, 05:29 PM
Thank you. Shadow eclipse understands what im saying. it may be the 3rd in the past two days but im tryin to make it so there are only a few every week
Old 03-16-2005, 05:31 PM
ohh and by the way those last 2 were asking questions. im tellin them they can just email me and ill give em the whole list
Old 03-16-2005, 05:40 PM
bighauns's Avatar
bighauns bighauns is offline
Send a message via MSN to bighauns
Re: Re: Talon 5speed swap
Not too much of a reason to jump all over him there bud.
You may want to do a write up on this swap and hopefully it can be put in the FAQ section or something, that would be a good thing to have, as yes it is asked a lot.
Just a thought.
"You can have everything in life you want if you will just help enough other people get what they want."
Old 03-17-2005, 11:34 AM
Erco90Talon Erco90Talon is offline
cant e-mail
i would have e-mailed you through the thread but said i cant i did have one question about the brake booster i swapped my 1990 eagle from auto to a 5 spd from a 1992 and went through hell but everything works but when i drove it the brakes were on all the time i wasnt sure if the new pedal assembley needed a new brake booster but i adujusted the nut on the pedal seemed to work but did you run into this problem????Also i needed to make a new rod for the clutch cylinder cause it wouldnt disengae the cluch did you have that problem at all???
Old 03-17-2005, 12:37 PM
Re: cant e-mail
[quote=Erco90Talon]i would have e-mailed you through the thread but said i cant i did have one question about the brake booster i swapped my 1990 eagle from auto to a 5 spd from a 1992 and went through hell but everything works but when i drove it the brakes were on all the time i wasnt sure if the new pedal assembley needed a new brake booster but i adujusted the nut on the pedal seemed to work but did you run into this problem????Also i needed to make a new rod for the clutch cylinder cause it wouldnt disengae the cluch did you have that problem at all???[/QUOTE
Use the pms! (Private message) Please!!
95 GSX 14.748
90 GSX
Old 03-17-2005, 09:00 PM
AngelOfNight 9's Avatar
AngelOfNight 9 AngelOfNight 9 is offline
So? If you don't like the topic he created then why do you even bother responding? You're not a moderator so ignore it.
*91 TSI AWD*
