Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 03-16-2005, 02:31 PM
timm6295 timm6295 is offline
Send a message via AIM to timm6295
Thumbs up D16 mine me swap
I was just wondering if anyone knew what head would bolt onto my 95 civic dx without any major mods
Old 03-16-2005, 02:43 PM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
Re: D16 mine me swap
the EX/Si head will, it's the D16Z6.
http://www.iapecc.com/mini_me.htm
Old 03-16-2005, 09:00 PM
Yea i kinda figured that the vtec head would but is there any way a b series will bolt up to it
thanks
Old 03-16-2005, 09:03 PM
and also is there anyway to convert it from sohc to dohc without swapping the motor
eventually i want to run a turbo with forged pistons and rods pusing around 13 psi around town with room to safely up it
Old 03-16-2005, 10:10 PM
CivicSpoon's Avatar
There is no Spoon
No the d-series blocks are only compatible with d-series heads, and the same with the b-series. And no there's no way to make a sohc into a dohc. I'd say either do the mini-me, swap in a d16z6 complete swap, or do an LS swap (b18b). The LS would be good because it's usually a little cheaper than the b16a, has more torque than the other b-series (except the Integra Type R engine), and has lower compression to it so it's boost friendly. And psi doesn't mean anything really. With different size turbos; 13 psi could be a lot or could be nothing. Smaller turbos spool quicker but max out sooner, where bigger turbos take more time to spool fully and can provide more hp. I'm assuming like the rest of us, you're trying to go the cheapest (price wise) possible. But if you're looking for some real power, it's going to cost you a serious chunk of change. Just don't rush to a decision, because chances are you'll pick something and then find a better way of going about it.
Old 03-16-2005, 10:28 PM
lkailburn's Avatar
lkailburn lkailburn is offline
Send a message via AIM to lkailburn
^^^well said well said
Old 03-17-2005, 01:09 AM
Medabots Medabots is offline
you are right, I figured out that fast cars cost money the hard way. I boght a B18 for my hatch and the engine and all the parts needed costed me around 1,100. I used to say "I'll never espend that kind of money on my car". But I was Wrong as hell.
Get ready to espend money,but take your time when deciding wich performance parts you are buying. And decide what mode you want to go wiht.
Still trying to get a GOOD price in a LS transmission...
Old 03-17-2005, 04:05 AM
civickiller civickiller is offline
Send a message via AIM to civickiller
cars are expensive, especially trying to make them fast
Team Lonely Drivers
Old 03-17-2005, 01:56 PM
Yea i guess i should just look into putting the Ls motor in my civic , i hear that dart makes a pretty good head package for it
