Go Back   Automotive Forums Car Chat > Chevrolet > Malibu
Old 03-16-2005, 02:15 PM
theothermac theothermac is offline
Send a message via AIM to theothermac
Stereo Removal...
Hey all...Are there any 'hidden' screws or anything holding the dash cover, over the stereo and a/c-heat controls? I need to get this p.o.s. stock cd player out and put my 'good' one in asap! Just dont want to break anything! (And yes...I've got the kit and the stupid/expensive little black box!)
Thanks!
Old 03-16-2005, 08:37 PM
Malibullsh*t Malibullsh*t is offline
Re: Stereo Removal...
I'n my 99 Malibu you just grab the plastic above the ashtray and give it a good yank and it comes right off, giving you access to the stereo mount
Old 03-16-2005, 09:55 PM
gapboi210 gapboi210 is offline
You have to pull off the trim around the ignition switch that says off, acc, on etc. Don't yank, thats when you break shit.
Old 03-17-2005, 11:22 AM
Sethkj Sethkj is offline
There's a black box? If I get another radio, do I have to have this special black box? What does it do?
Old 03-17-2005, 01:24 PM
Re: Re: Stereo Removal...
Don't know which years (mine is an '03)...the little black box keeps the factory chimes, warning bells, the delayed radio on after you turn the car off...and whatever else??? They are proud of them too! $$$
Old 03-17-2005, 01:25 PM
I was thinking that needed to come off...does it 'pop' off or what?
Thanks!
Old 03-17-2005, 01:40 PM
My car is a '99 - if I got another radio, should I get the black box? If so, where do I get 'em?
Old 03-17-2005, 04:11 PM
The trim around the ignition switch just pops off.
Old 03-26-2005, 12:20 AM
lostmypicks lostmypicks is offline
no dude you dont need the black box
dont go and get another one
mine still runs all of the normal nosies and crap
if you do not have it there is no differices
Old 04-11-2005, 04:57 PM
odiHnaD odiHnaD is offline
You will only need the "black box" if you have a 01 or newer malibu, what that black box is is a databus II interface emulator basically around 2000 GM decided to start using a data interface that would allow different parts of the car to communicate with each other, IE security system, PCM, XM, Onstar, etc. and in doing so they made the radio control chimes (low fuel, headlights on etc.) and in some cases custom seat adjustments and so forth, by using the black box it makes the car think the stock radio that it normally communicates with is still there, in a few newer model GMs if you don't use a black box it can trip a check engine light, so in short if you have a 2000 or older malibu, you don't need it.
Old 05-04-2005, 05:12 PM
malibugtp malibugtp is offline
how do i reset the stereo loc code
Old 08-16-2005, 09:33 AM
monkey123's Avatar
monkey123 monkey123 is offline
Banned
2002 oem radio ?
How about this situation, then?
I have a 2002 malibu with the oem AM/FM CD player with RDS. I can get the upgrade OEM unit, which adds a CD player to the mix. Can I just yank the old one and puy this in it's place without screwing around with codes and the car computer? If not, is it doable DIY, or is a dealer needed???
