Old 03-16-2005, 01:43 PM
mystic37601's Avatar
mystic37601 mystic37601 is offline
1995 Eclipse screetches when wheel is turned
I know the steering boot was busted completely. It was replaced & grease packed in it. They thought this was what was causing that noise. But it still screetches really bad when the wheel is turned. I know whatever it is is on the passenger side front. Any idea what else could be causing this awful noise. It's very obvious, it can be heard outside the car from quite a ways away
Old 03-16-2005, 02:00 PM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
Re: 1995 Eclipse screetches when wheel is turned
I know that power steering pumps have a tendancy to make really nasty noises sometimes. Have you checked you fluid?
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 03-16-2005, 06:11 PM
96spyderman's Avatar
96spyderman 96spyderman is offline
Send a message via AIM to 96spyderman Send a message via MSN to 96spyderman
Is it a groaning? or a screeching? If it's a groan you probably need fluid or new pump... if it's screeching it's the belt.. replace or tighten existing belt
"A man's greatest work is to break his enemies, to drive them before him, to take from them all the things that have been theirs." -Ghengis Khan
Old 03-16-2005, 06:58 PM
Trueeclipse's Avatar
Trueeclipse Trueeclipse is offline
I had a screetching noise realllly bad and loud I just replaced the belt and it was fixed.
Old 03-18-2005, 11:35 AM
kjewer1 kjewer1 is offline
AF - Advisor
Put your car type in your sig or mention it in your post, or prepare to get kicked in the mudflaps.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 03-19-2005, 04:07 PM
lostmypicks lostmypicks is offline
Re: Re: 1995 Eclipse screetches when wheel is turned
why dose he need to put the car in the post
Old 03-19-2005, 05:33 PM
Shpyder's Avatar
Shpyder Shpyder is offline
Moderate moderator
its a requirement that facilitates answering queries as soon as possible, instead of running around and wasting time between 2-5 posts asking about what car he has.
The daily driver. The weekend cruiser. The lazy shop hog.
Old 03-19-2005, 07:53 PM
oh sorry I am new to the forums
