Go Back   Automotive Forums Car Chat > Chrysler > Concorde
Old 03-16-2005, 12:35 PM
removalmachine removalmachine is offline
Question Removing Door Panel
I have to change to power window switch on the driver's side door - does anyone know how to take the panel off? Tried to take it off last night - no luck - I would have started to crack it if I kept prying - even after taking the screws out.
Thanks
Old 03-17-2005, 05:48 PM
cbeck cbeck is offline
Re: Removing Door Panel
I don't have a concord, so I might not be of much help.
But you took the screws out of the door handle area too?
I'm not a mechanic, I'm the guy people bring their car too when they don't run. I usually scratch my head and tap on stuff, then call the dealer to see if they can help me find the carburetor.
Old 03-20-2005, 11:34 PM
theFREAKnasty82's Avatar
theFREAKnasty82 theFREAKnasty82 is offline
If your trying to take out the power window switch on a 98-04 Concorde, you don't need to take out the door panel, just get a small screwdriver, and pry it out from the door panel. But if you are trying to get the panel off, try taking the screw by the door handle, it's hidden by a little cover in the handle, the door pull handle has a screw covered by the same cover as in the door handle, there are 3 on the bottom edge of the door, two on the recessed area that fits into the dash and you have to remove the speaker grill to remove the last 3 screws that hold it in place. After that, the panel should come off easily.
Daily Overhauls Do Get Expensive
Dangerous On Days Gears Engage
Dead On Day Guarantee Expires
Dead Or Dying Gas Eater
Department Of Defense Garbage Equipment
Dodge Owners Don't Get Excited
Don't Overdrive Gutless Engine
Drips Oil Drops Grease Everywhere
1995 Dodge Dakota SLT 3.9 V6
1995 Jeep Grand Cherokee Laredo 5.2 V8 4X4
Old 03-22-2005, 08:22 PM
Bizzy102 Bizzy102 is offline
I just did my panel and thats all you have to do is use a plastic screwdriver to pry out the control section.
Old 05-24-2005, 06:59 AM
RayQix RayQix is offline
Send a message via AIM to RayQix Send a message via Yahoo to RayQix
Thanks
There ARE screws in it.
See my post about the window...if it'll help you.
