Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 03-16-2005, 12:12 PM
riverside4 riverside4 is offline
Question 99 Ram Rattle Behind Steering Column
This noise is driving me crazy! I can't figure it out! There's a rattle behind my steering column, behind the pedals that occurs only during acceleration...stops when my foot is off the gas. Sounds like a loose nut, but I know it's not. Bad gas? Something else? Can anyone help?
Old 03-16-2005, 12:29 PM
lownloud lownloud is offline
could be the steering coupler on the steering shaft,I think I read an article about this somewhere,seems to be a common problem for the new dodges.
Old 03-16-2005, 09:15 PM
1thunder 1thunder is offline
Re: 99 Ram Rattle Behind Steering Column
is it like an engine ping or like marbles sound in engine?
Old 07-17-2005, 07:56 PM
beachbumnwfl beachbumnwfl is offline
I own a 99 ram 1500. I have had that same rattling sound from day one, it is pretty annoying. You can't really figure out exactly where it's coming from either. Has anybody figured this out and had it fixed? Any help would be nice.
Old 07-17-2005, 09:43 PM
Blylock Blylock is offline
if it sounds like its coming from the engine, its called a spark knock. sometimes its bad gas, but the 97-00 rams are prone to blow their intake gaskets which cause that sound on acceleration. do you notice yourself going through oil frequently? thats a sure sign of the plenum gasket failure. anyway look into it and read this TSB, it will explain in detail.
http://dodgeram.info/tsb/2000/09-05-00.htm
hope this helps.
1998 Ram 1500 SLT 4x4
5.9L
Dynomax Performance Dual Exhaust
KN cold air intake
Bosch +4 Platnum Plugs
180 Degree Thermostat
I would suggest to anyone with a Ram to convert to a performance exhaust, especially if towing alot.
