Old 03-16-2005, 11:24 AM
megahertz megahertz is offline
Send a message via Yahoo to megahertz
loss of spark while driving
95 taurus 3.0 v6,suddenly lost spark.codes are 211(profile ign.pickup)AND CODE 212(loss of ign.diag. monitor(IDM) short to ground in spark output circuit)So far I have checked ign.control module and coil both are good.just no spark.What else should I check?
Old 03-16-2005, 08:18 PM
Smith1000 Smith1000 is offline
Re: loss of spark while driving
Is it sparking at the plugs? How is the coil wire? Maybe there is a loss of timing rather than a loss of spark if those things seem to be working. It might be good to check all ground wires around the ignition module. Possibly there is a crank position sensor to check. If it has a distributor, there may be a bad coil pick up sensor in the distributr, or if distirbutorless, a bad throttle positon sensor?
Old 03-17-2005, 06:33 AM
I checked the wiring,all seems ok.I have received no indication(code) that the pickup coil is bad,would hate to buy one just to find out that wasn't the problem.Control module is good,coil is good just no power going to the coil.
Old 03-17-2005, 03:25 PM
Re: Re: loss of spark while driving
Update: I replaced distributor(including pickup coil and ICM) car ran great for about two blocks,then developed same problem,loss of spark.
