Old 03-16-2005, 10:48 AM
civicHatch civicHatch is offline
Send a message via AIM to civicHatch
88-91 dual-point Conversion BREAKTHROUGH
hello,
I posted a while back and asked about using a 88-91 si harness on a b16a1 with the hasport subharness on a 90 4dr dual-point. Some people replied that you cannot use the si harness, they said it will not work and u should always modify the dual-point.
Well....
Old 03-16-2005, 10:53 AM
Re: 88-91 dual-point Conversion BREAKTHROUGH
I think it is easier to use the si harness with the hasport to wire the engine out of the car so u dont have to modify any of the engine harness or add wires for the resistor box or injectors on the engine side. All u have to do is use your old dx connector and re-pin the si wires into the dx connector on the resistor box side. Then u need a body-side harness connector for the 6 wire plug on the passanger side. Then you can just run all your wires directly to the ecu ( 4 new injector wires, ignighter coil, etc.) In the end, the swap is much cleaner as the engine harness is NOT modified at all. Let me know what u think, I just finished the swap and we have no codes and it is running great. Very clean engine bay as well. Contact me if you need help.
Old 03-16-2005, 11:05 PM
Hilikus Funkin's Avatar
Hilikus Funkin Hilikus Funkin is offline
Send a message via AIM to Hilikus Funkin
oh yeah i had a question about mpfi swap. I think someone said that if i use obd1 injectors that i wont have to have a resistor box? Because my friend is selling me a VX intake manifold with everything for $10. It will plug right in right? I mean it will work when i do the regular wiring without a resistor box right?
1991 Honda Civic DX Sedan
Old 03-16-2005, 11:15 PM
travagliante's Avatar
travagliante travagliante is offline
well a vx intake manifold is like a HX civic or HF crx. Fuel economy. The manifold and throttle body are smmmmmmalllllllllllllllllll!!!!!!!! You dont want that. All of the sensors, injectors and crap are good. But IMO the manifold isnt worth anything besides taking the TPS sensor and other stuff off of.
Old 03-16-2005, 11:19 PM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
Don't use a VX manifold. Everything else sure, but the VX manifold is small. I refer to that manifold (and the 5th gen CX manifold) as a pea-shooter. You'd be better off with any of the other ones than those 2.
Old 03-17-2005, 12:21 AM
civickiller civickiller is offline
Send a message via AIM to civickiller
yeah but the work you went through sounded alot harder than modifying your car for mpfi with a dx harness. and with the dx harness, i switched back to dpfi in like 5 mintues. i wonder how long it takes to switch back to dpfi with your setup
Team Lonely Drivers
Old 03-17-2005, 09:41 AM
1. Im just doing the swap so i dont have to later, because when i get a new engine itll have a new manifold.
2. why would you switch back to dpfi civickiller?
Old 03-17-2005, 09:42 AM
nobody answered my question lol, do i need the resistor box? and does it wire in the same as an si manifold?
Old 03-17-2005, 11:57 AM
i had to switch back to dpfi because my b series motor was blown when i got it so i had to go back to my 1.5 dpfi.
you dont need a resistor box when running obd1 injectors. you take the power wire from you current injectors or the biggest yellow wire in the drivers side strut connector and then run 4 wires from each injector to the drivers side strut harness and tie it in with the power wire
Team Lonely Drivers
Old 03-17-2005, 03:08 PM
even though i have obd1 injectors im probably gonna be obd0 still, i still wouldnt need a resistor box right? heres a pic of my manifold, i picked it up a few hours ago.
Old 03-17-2005, 07:02 PM
yup if yoru still obd0 but running obd1 injectors, you still dont need the resistor box. the signal sent to the injectors by the ecu is all the same, its just a matter of powering them right that varies between cars
Team Lonely Drivers
Old 03-17-2005, 10:34 PM
oh ok thats cool, thanks man. I hope my friend has the TB tomorrow so that its complete, i just need a dizzy, and a computer now. SHould i get an si wiring harness or do i not need it? Honestly i know nothing about wiring. I can follow directions though. lol
Old 03-18-2005, 05:59 AM
do you have the injector harness for the obd1 injectors ?
dizzy plugs arent really needed, just for cosmetic looks. and to make it look cleaner for hte wires you need to run from the ecu.
Team Lonely Drivers
Old 03-18-2005, 11:12 AM
bambam89lx's Avatar
bambam89lx bambam89lx is offline
AF - Advisor
Send a message via AIM to bambam89lx
this has been done before...i actually posted about it. I did it for my car....it is a much cleaner look. But, it is a whole lot easier to add 4 wires than to repin the whole engine harness....you'd need the diagrams (which i've made myself) to do it.
Jumper harnesses, mpfi conversions, engine harness conversions, vtec subharnesses, etc.
The absolute lowest prices at the absolute highest quality. Trusted. Guaranteed.
Click the image above to visit our online store!
Hastings Bseries and Dseries piston ring kits (inc. ZC) - $49 shipped
Old 03-18-2005, 06:00 PM
Re: Re: 88-91 dual-point Conversion BREAKTHROUGH
wait so i need an obd1 harness for the injector wiring but i dont need a new dizzy? Im confused...
