Old 03-16-2005, 07:47 AM
Tech_n's Avatar
Tech_n Tech_n is offline
Comparing strut
I wanted to know if the KYB struts were a good buy compared to the Dealership struts? If so, how many mile can you get out of the factory strutt, compared to the KYB Struts?
Old 03-16-2005, 09:36 AM
BIG-L's Avatar
BIG-L BIG-L is offline
Re: Comparing strut
First the KYB's have a lifetime warranty and from what ive heard, factory strut's are only good for about 30,000 miles and then they start fading away.As they fade away you never really notice it,untill you buy new one's and then you will notice a nice difference in ride again.
~Larry~
ClubGP Member 6530
Since 2001
Old 03-16-2005, 12:06 PM
Tech_n's Avatar
Re: Comparing strut
Have you ever purchase struts off of Performance 3800 before. Also, are KYB GR-2 good struts
Old 03-16-2005, 12:17 PM
BIG-L's Avatar
Re: Re: Comparing strut
Ive bought some parts from Rob at 3800 but not struts.Ive got the GMPP konis.You might try tis site that Ive told other's about for the KYB struts.
[email protected]
KYB GR2's for a full set of 4 @ $170.00 shipped
ClubGP Member 6530
Since 2001
Old 03-16-2005, 12:18 PM
Tech_n's Avatar
Re: Comparing strut
Also, what is the difference between the Gas and the Sensor trac struts? Furthermore, what are the factory struts, Gas or sensor?
Old 03-16-2005, 12:27 PM
BIG-L's Avatar
Most all new strut's are Gas and Sensa-Trac is just a name.
Monroe makes the Sensa-trac strut.Monroe also makes one called the Quick Strut which is a plug and play strut and ready to bolt in.
Quick Strut™
Quick and easy... remove and replace one piece!
No need to take apart entire assembly.
No need to compress coil springs.
Do the complete job right the first time.
Enhances the handling, safety and performance of your vehicle.
1. Bearing Plate
2. Upper Spring Isolator
3. Upper Spring Seat
4. Coil Spring
5. Boot Kit
6. Lower Spring Isolator
7. Sensa-Trac™ Strut
The revolutionary Monroe Quick Strut unit is the first complete, ready-to-install replacement strut assembly available! Monroe Quick Strut units include all the components required for strut replacement in a single, fully-assembled unit. They feature pre-assembled replacement bearing plate, upper and lower spring isolators, upper spring seat, coil spring, boot kit, and a premium Monroe Sensa-Trac® strut. This breakthrough design saves on installation time by eliminating having to disassemble components and compress the coil spring prior to installation. Each Quick Strut assembly features application-engineered valving to optimize each vehicle's unique ride and handling characteristics.
Old 03-17-2005, 12:06 PM
KX2000GTP KX2000GTP is offline
Re: Re: Re: Comparing strut
[email protected]
Is GMPP GM Performance Parts?
Old 03-17-2005, 12:41 PM
BIG-L's Avatar
Re: Re: Re: Re: Comparing strut
Yes,it is the same.
