Old 03-16-2005, 12:18 AM
TFFantasy44 TFFantasy44 is offline
amp advice
Hey all, I'm havin troubles with my nine.1 amp and would like some input as I won't be able to get to it until around Friday...here's how it's setup:
I originally had it running an eD 12O.44 (wired to 2 ohms) since like november, december I think. I set the gain at a tad above a quarter, and it sounded great, no problems. A few weeks ago, I got a 16Ov2 (wired to 2 ohms) I set the gain to less than a quarter and threw it in a 2.25ft^3 ported to 30 hz. While driving yesterday it went into protect with no funky sounds or smells, so I figured something had popped loose. I checked wires/fuses/etc. and everything was ok. I turned the car back on and it plays for 10 maybe 20 seconds, and goes back into protection. Rinse and repeat countless times. I've checked and rechecked connections and fuses and it looks good, and I'm fearing that there's a problem with the amp, but I won't be for sure until I can hook my old one up on Friday in the same setup. I don't see how it could have blown as it's been running the same way perfectly for about 5-6 months now, and I've recently turned it down. I'd just like to get some input before I tear it all apart Friday...thanks guys, sorry for long read.
Old 03-16-2005, 11:12 AM
germanyt germanyt is offline
Re: amp advice
im not really sure why that happens. i had the same problem with a punch 6002 amp. after running it for a while (or i should say abusing it for a while) it would cut out for a few seconds and come back on.
Old 03-16-2005, 11:48 AM
bumpinstang77's Avatar
bumpinstang77 bumpinstang77 is offline
Send a message via AIM to bumpinstang77
Re: amp advice
if you don't figure it out send it back....... the three year warranty kicks ass!
2002 Ford Explorer Limited
D31 yellow top
Kenwood DDX-7017
2 Ascendant Audio Avalanche 18's
13 cuft NET ported box tuned to 27hz
Autotek Mean Machine MX3000.1
Ascendant Audio Arco component set
Orion 275SX (Mids)
PPI Art Series A200 (tweets)
Poly Mids for rear fill to come soon.
Old 03-16-2005, 11:27 PM
Re: Re: amp advice
I'm guessing thats what I have to do, but I really don't want to wait. My 16O needs some more playtime, and I just got a port and everything :-( Oh well.
And it doesn't cut out for a few seconds and come back on, it turns for a few seconds then goes into protect until I turn it off for a while.
Old 03-18-2005, 12:14 AM
Integra4200's Avatar
Integra4200 Integra4200 is offline
Send a message via AIM to Integra4200 Send a message via MSN to Integra4200 Send a message via Yahoo to Integra4200
yea when i had my sub in my car my amp used to cut out for like a min then just come back on out of kno where... not sure why
96 Jeep Grand Cherokee Laredo
5.2 L 135k miles.Flowmaster muffler/mangaflow cat
I wrecked it about a month ago. damage is the front end passenger side. i have 3 good 80% tread 30" wild countrys bought from les schwab. (4th one poped due to accident.)I also have brand new (still wraped in plasitc) front/rear bumper covers. the grey ones. also a brand new chrome grille.let me know if you need something. it will be going to the junk yard in a few weeks so hurry
Old 03-18-2005, 12:29 AM
ngsm13's Avatar
ngsm13 ngsm13 is offline
Send a message via AIM to ngsm13
Re: Re: Re: amp advice
Maybe a voltage problem?! What's you electrical system like...sound like a voltage drop...
NG
I design custom enclosures!
And...my sig is short!
Oh and.. YOU suck balls...
Old 03-18-2005, 08:56 AM
Re: amp advice
I don't think its a voltage drop as it never turns back on until I shut the car off, let it sit for a while, then turn it back on. Today I should be able to swap amps and see if thats the problem...
Old 03-18-2005, 09:15 AM
bjboertje's Avatar
bjboertje bjboertje is offline
Re: amp advice
maybe the power turn off does something when you turn the car off, it could still be voltage drop then, couldn't it?
2001 Ford ZX-2
Alpine CDA-9855
SAX 100.4
Rainbow CMX 265 front stage
Stock 5X7 rear fill
Hifonics BX1505D
TC-5200
Old 03-18-2005, 09:24 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
sounds more like a low impedance problem ..... you may have a stray wire crossing over at the amp speaker terminals, or a blown sub, or they are wired at too low an impedance - or the amp is just bad.
Old 03-19-2005, 06:19 PM
ponchonutty's Avatar
ponchonutty ponchonutty is offline
Re: amp advice
Why not meter it all out instead of guessing?
Silverado Ext. Cab 4x4 z71
Pioneer 4900mp
Orion P6.2 Componet sets front
Orion C63 Coax rear
DirectedVideo 9" all in one DVD with surround
2007 SATURN OUTLOOK AWD XR with full entertainment package
Old 03-20-2005, 02:31 PM
Re: amp advice
I think I got it figured out, its not low impedence (2ohms & its 1ohm stable) or anything...I took everything out and rewired it all, and then set it all back up. As long as I don't go anywhere, it plays fine. But as soon as the amp moves a gets bumped or anything, it cuts out, no matter what I have hooked up to it. I don't really want to send it back as I'm lacking in the money department, but I guess I have to, huh?
Old 03-20-2005, 04:22 PM
Re: Re: amp advice
Sounds like it. The problems I've heard on these amps is that they can't take too much abuse on the RCA inputs. If you have pushed on them too hard or something, it causes the solder to break loose or worse, cracks the board.
Pioneer 4900mp
Orion C63 Coax rear
Old 03-20-2005, 11:36 PM
Ahh, the rca's didn't have much slack to 'em I bet thats the problem. Thanks poncho!
