Old 03-15-2005, 10:02 PM
milton666's Avatar
milton666 milton666 is offline
Send a message via MSN to milton666
boost leak?
ive been wtaching my boost gauage and messing with my car cuz its been running kinda slow lately, but it seems like it takes awhile to hit 14psi then it starts slowly losing boost, is that normal or do i have a boost leak?
95' Gs-t (broke the fuck down...)
68' Mustang getting reassembled right now, 82.763% done
http://www.tagworld.com/milton666
Old 03-15-2005, 10:31 PM
96spyderman's Avatar
96spyderman 96spyderman is offline
Send a message via AIM to 96spyderman Send a message via MSN to 96spyderman
Re: boost leak?
Go to www.vfaq.com and build yourself a boost leak tester. It is a valuable tool to have!!!
That and go through ALL your piping and check to see if everything is tight.
Which BOV do you have? 2gen bov's suck ass!!!!
"A man's greatest work is to break his enemies, to drive them before him, to take from them all the things that have been theirs." -Ghengis Khan
Old 03-15-2005, 11:07 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
Re: boost leak?
also if you are on your stock t25 turbo its normal for the boost to drop off above 6000 rpm
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 03-15-2005, 11:33 PM
97GSTspyder's Avatar
97GSTspyder 97GSTspyder is offline
Send a message via AIM to 97GSTspyder
Re: boost leak?
could be a boost leak. does your car run rough/jerky at all? if you're running the stock T25, remember it doesn't start to spool till around 2900rpms, and anything above 5500 you'll see a drop in boost. like spyderman said, build yourself a leak tester.
Old 03-15-2005, 11:59 PM
viet_boiiiii's Avatar
viet_boiiiii viet_boiiiii is offline
Send a message via AIM to viet_boiiiii
Re: boost leak?
Its most likely a boost leak because the boost should be set at 14psi around 3700rpm and pulls all the way to 5500-6000 where it drops back to like 13 but thats normal.
new 2006 Scion tC - 5spd
-magnaflow catback
http://www.cardomain.com/ride/2088489
~~~R.I.P (7-2-05)~~~
1998 Eclipse Gst - 5 spd
Old 03-16-2005, 12:51 AM
dsmodder dsmodder is offline
Send a message via AIM to dsmodder
Re: boost leak?
boost leaks are common if you have never checked for one before.
