Good idea or Bad idea?
(3000gt sl) Alright here's the deal I can either rebuild my engine by putting in high compression pistons, polishing the heads, get new exhaust, headers and an intake. That I believe is in my budget. The other is to just get a vr4 engine which is around 2.4k not counting instaling. Any ideas on how much HP i can gain from my first option? Is it possible to get 300hp with all that? Which option would you recomend I do with a limited budget. Thanks for the help.
Re: Good idea or Bad idea?
Check the NA upgrading bible in the FAQ for approx. hp guesses. Also know you will need more than just the vr4 engine...
96 3000gt vr4 -K&N FIPK -Proboost mbc -Cusco front + rear strut bars -Greddy type-s -ATR downpipe -no cats -15Gs, 3sx aluminum pulley, FMIC, SAFC, walboro pump, EVO 560ccs, and Meth Injection Kit all waiting to go in shortly. Your 1996 Mitsubishi 3000GT VR-4 is the 92nd out of the 315 that were made that year. Only 21 of which are exactly identical. |
If it were me, I would save up for a VR4 (which I did after buying the SL). But it would be very cool to have a monster NA 3000GT, if you do that you gotta go all out though.
1995 3000GT VR-4 Installed: ESP front precat eliminating downpipe, test pipe, RF-1008 K&N, Dejon tool Y pipe, 1G DSM BOV, MSD wires, Guted rear pre cat, ISSPRO EV Marine boost gauge, IPO MBC, EGR blockoffs, Palm m515 dataloger setup, NGK iridium plugs, SPEC stage II clutch 500ft/lb, 5300k HID plug and play setup. Soon:Topline Engineering ground wires. |
Ya thats what i thought. What else could I do for those extra horses?
Re: Re: Good idea or Bad idea?
I was contemplating building a monster SOHC NA. Then I realized I was going to be dumping a lot of money into the car and it still wouldnt be fast enough for me. I know with heads being done up, cams, high compression pistons etc I woulda had a fast ass SOHC but it would be limited to what I did. No more could add more power, nitorus/forced induction is a basic no no for a streetable high compression(11:1 or 12:1) car.
I decided to save my money and am going to eventually single turbo it. With a single turbo once I get all the supporting mods I could always upgrade and boom instant power. I also am going to add a VR4 to my stable.
ya after reading up on the bible and other sights i realized that i can dump thousands and still not get the performance of a vr4.
Hey stealthee i've thought about going single turbo bc i'm most likely gonna get a vr4 within a year or 2. I can't wait that long and stay stock. What would i need to go single turbo and how much cash am i looking at? lol please don't say i need a vr4 trans
Re: Re: Re: Good idea or Bad idea?
NO you can keep your stock tranny. You might want to look into an lsd though for traction woes. It really depends on the set up you go with. A guy on 3si is developing a single turbo kit for SOHC's that is looking to run about $3500 for everything. Thats a t3/t4 hybrid turbo, header, crosspipe, fmic, and about everything you need to hook it up. The only other thihngs you would need would be injectors and a SAFC. Yes thats alot of money to put into a FWD SOHC but it will be a hell of a car to beat from a roll.
![]() You might even find someone who is getting rid of a set up. You can also consider doing a TT conversion keeping the 10:1 compression. Basically same as doing a single T except everything will be bolt on.
