Go Back   Automotive Forums Car Chat > GMC > Jimmy
Old 03-15-2005, 07:09 PM
GMCSeamus's Avatar
GMCSeamus GMCSeamus is offline
Send a message via AIM to GMCSeamus
Question Wiring problem/question
about a month ago, i wired some led's in my ground effects for additional turn signal light. I grounded the led to the turn signal wire and powered it to a fuse in my fuse box. It worked fine, when i turned on my turn signal, it would alternate between the bumper light and the led's in the ground effects. During the winter, the wires got ripped out of the back of a couple led's from the snow so i unhooked it from the fuse.
Recently i tried to do it again, but the passenger side wont work. I grounded it to the same part where i spliced it before, but it wont work. The drivers side will work though. All of the turn signals, parking lights and stuff work properly... but i cant get the leds to work anymore on the passanger side
any help would be appreciated
~DK
Old 03-15-2005, 11:46 PM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
Re: Wiring problem/question
resistor could be burnt (or do your led's have the resistor built in?) have you tried taking the good led on the driver's side and putting it in the passenger?
Old 03-16-2005, 12:48 AM
GMCSeamus's Avatar
Question
its not the led, its something with the wiring, because i tried hooking the same led up to both sides, it worked on the drivers side, but when i put it on the passengers side there was nothing
'96 Jimmy SLS 4-door 4wd, Fully completed sound system, addiction to lights (8500K Headlights, PIAA Fog lights, LED's everywhere, enough strobes to be considered a felony), Cold air intake, intake sensor chip, tornado air twister, flowmaster exhaust.
Check me out in CarDomain and DON'T FORGET TO VOTE!!!!
http://www.cardomain.com/memberpage/460285
Thanks
~DK
Old 03-16-2005, 08:49 AM
rlith's Avatar
Could be the socket itself.. Follow the hot for that back to where it's supposed to get power from and use a multimeter to check continuity.
